Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > turn signal check disable
      04-22-2014, 01:20 PM   #1
taranonline
28
Drives: Man
Hello
I have e90 lci halogen headlights and I got led turn signals py24w.
When I start the car they flickr for sometime. I was unable to find any codes to disable them.
The following code is not present in my frm file.
KALTUEBERWACHUNG_BLK_VO
Attaching the frm file.
If anyone can help, Thanks in advance.
Thanks
      04-22-2014, 07:46 PM   #2
taranonline
28
Drives: Man
Bump
      04-23-2014, 04:26 AM   #3
taranonline
28
Drives: Man
KALTUE_FRA_V_M1_13_M2_40
The above code works fine to code out cold check on lci halogen headlights turn signals.
Thanks
      04-23-2014, 10:49 AM   #4
dwells
ಠ_ಠ
dwells's Avatar
74
Drives: Monaco Blue 335i coupe
Thanks
That only disables the cold (startup) checks. You'll also want to disable:
  • WARMUE_FRA_V_M1_13_M2_40 - warm (running) check
  • CC_MELDUNG_FRA_V_L - check control error for left
  • CC_MELDUNG_FRA_V_R - check control error for right
| 335i coupe | Monaco Blue | JB4 G5 ISO | Style 313M | Huper 40% tint | Aero lip | CSL trunk spoiler | M3 sideskirts
| Paint-matched grilles | Painted reflectors | GP Thunder II angel eyes | Smoked LED sidemarkers | Self-coded |
      04-24-2014, 02:17 AM   #5
taranonline
28
Drives: Man
Acutally I didnt get any errors only flickering during cold checks.
Thanks anyways
      04-24-2014, 08:39 AM   #6
dwells
ಠ_ಠ
dwells's Avatar
74
Thanks anyways
If the warm check is still enabled, I can guarantee you they're flickering a few times every several minutes. You won't notice it, but for safety's sake you should code it out. You can skip the check controls if you're not seeing any errors, though.
      02-10-2019, 06:20 AM   #7
rbu_tuninq
Romania
Drives: e92 M3
hi:
how can you disable them when they are coming like this
CC_MELDUNG_FRA_V_L
wert_01
CC_MELDUNG_FRA_V_R
wert_01
change the wert to nicht_aktiv ?
I found the other two warm and cold
KALTUE_FRA_V_M1_13_M2_40 nicht_aktiv
WARMUE_FRA_V_M1_13_M2_40 nicht_aktiv
any help appreciate
