04-21-2014, 08:11 PM | #1 |
102
Rep 775
DIY: M Performance rear diffuser
Hi Gents,
Just another DIY for those looking to tackle a easy job. First if you plan on replacing the diffuser; make sure you chose if either you have M-Performance Exhaust. If you do not, chose the standard exhaust and you will need to get the adapters to extend the tips! I am installing Performance exhaust tomorrow; so you will see why you will need the adapters if you do not have M Performance exhaust. ---- Tools needed:
Difficulty 1-5 (5 being hardest): 2 ---- Start by painting, or leaving your diffuser primed. I chose to paint my diffuser and than keep the center gloss black. You can do this on the ground with no hoists if you have not lowered your car yet. Go underneath the vehicle and removing the six 8mm bolts. They have speed nuts on the exhaust shield. Remove the expanding pin on both sides of the diffuser. They are right behind the 8mm. You will use a flat head screw driver here to pull these out. Start by slowly pulling way on a corner you will hear the clips start to come loose from the bumper. Installing the new bumper was a little tricky with the clips. They are extremely tight and require A LOT of force. I'm not exaggerating when I say a lot. I had to put all of my 180LBS into each clip right underneath with WD40 on top of the clip. Do not be surprised if you have to spend upwards of a minute pushing on some of the center clips.This photo shows the clips not all the way in. Here is a photo after really pressing on the diffuser to get those clips in. Was rather painful!
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 |
04-21-2014, 08:29 PM | #2 |
***** noob
1366
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Awesome...now i see why it needs the perf exhaust
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
04-21-2014, 10:14 PM | #4 |
Rep 134
Overall, how do you feel about the appearance? Do you feel it's aggressive enough? I haven't been able to make up my mind on the M Perf diffuser based on pics.
04-21-2014, 10:20 PM | #5 | |
102
Rep 775
04-21-2014, 10:23 PM | #6 |
Rep 134
Makes sense. Definitely think the exhaust will complete the look. But glad to hear the diffuser's features are pretty pronounced! That's what I was most curious about.
04-21-2014, 10:25 PM | #7 |
102
Rep 775
Also painting it gloss black really made them pop. The fins are 3 inches out from the base in terms of height
04-22-2014, 08:21 AM | #12 |
4650
Rep 6,026
I understand what you want to achieve, and the first photo looks great....well lit, looking up from below. The concern for me would be that one never sees it in that lighting or angle on the road. The second to last photo is much more representative, and unfortunately, the surface detail of the fins in black pretty much disappears.
I went through a similar exercise on another brand of vehicle not too long ago, and wound up painting the entire diffuser, just so I could see that I really had a diffuser there. Going from the original black CF to bodycolor made a huge difference. |
04-22-2014, 08:48 AM | #13 |
102
Rep 775
I'll take a more direct photo
07-25-2014, 09:03 AM | #15 | |
215
Rep 661
07-25-2014, 08:33 PM | #16 | |
Rep 197
Pic here: http://www.2addicts.com/forums/showp...9&postcount=11 |
07-26-2014, 06:23 AM | #18 |
Rep 197
M Perf tips and adapters. Note that u have to cut ~120mm off of the end of each exhaust pipe in order to fit the adapters. Not a big deal...just FYI.
07-26-2014, 09:08 PM | #19 | |
23
Rep 167
07-28-2014, 08:21 AM | #21 |
23
Rep 167
