is there a way to go from manual mode to sport in auto trans?
04-19-2014, 09:08 PM | #1 |
11
Rep 77
Drives: 2015 535i xdrive, 2014 x5 35i
i'm relatively new in an e90. i like sport mode, but i don't like how the "sport mode" holds gears at high rpms when i accelerate hard, so i'll often shift it and that of course throws it into manual mode. is there a way to put it back into "sport mode" from "manual mode" without going back to the normal drive first?
04-19-2014, 09:23 PM | #2 |
56
Rep 1,464
Drives: 2009 BMW 335xi
Not that I know of...
04-19-2014, 09:35 PM | #3 |
356
Rep 928
Drives: 2007 328i Coupe, ZSP, Premium
No.
04-19-2014, 09:43 PM | #5 |
11
Rep 77
normal drive is for when i don't feel like going fast. maybe on the highway with little traffic. but once i need to accelerate around, i go into sport, then i shift into manual, but then i want to go back to sport. guess you can't do it. too bad...
04-21-2014, 03:13 PM | #7 |
23
Rep 322
When in "D", your car will automatically chose a program (I believe there are about 5 'modes') that is close to your current driving style. So, if you drive aggressively, it will automatically shift later, down shift (engine braking), etc.. If you drive it easy, the engine motor management will adjust and shift up quickly (fuel economic).
An example: let's assume you're a chilled driver. If you'd cruise 30mph and suddenly hit the accelerator (not full throttle, but say 75%), the engine might stay in the same gear and not down shift. If you'd been driving aggressively for the last minutes, and were in the same situation. Then, after hitting the accelerator, the engine for sure will down shift. By the way, if you press the accelerator 'through' the resistance (kick-down), you will overrule the previous gear-shift mode and the car will choose the most suitable gear in order to accelerate as fast as possible. In other words, there is no need to shift to DS mode, the car automatically recognizes your driving style and adjusts the gear shifting pattern. |
04-21-2014, 03:22 PM | #8 | |
1645
Rep 2,494
04-21-2014, 07:04 PM | #10 | |
16
Rep 102
Shake & bake!!
04-21-2014, 07:29 PM | #11 | |
Thats all you need to know.
43
Rep 1,188
- M2 2018 LBB / Black
- X5 F15 2016 Mineral White / Black 1981 Delorean number 6489 |
04-22-2014, 10:01 AM | #13 |
356
Rep 928
Why wouldn't you be driving in manual mode most of the time anyway? That's by far the most fun way to drive a steptronic. I only leave it in D when I am in a parking garage, bumper to bumper traffic, or cruising on the interstate, assuming I just need to stay in one lane.
04-22-2014, 10:11 AM | #14 | |
13
Rep 342
Drives: E90 Monaco Blue 335i xdrive
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
04-22-2014, 10:54 AM | #15 | |
453
Rep 2,973
Although a switch to put the car into complete manual mode would have been ideal.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
04-22-2014, 11:34 AM | #16 |
43
Rep 1,188
I just noticed something else, if you hit the paddle at a light and go into manual from D it will not switch back to "D" until you move. I have a double clutch in my car but a regular auto might do that as well.
04-22-2014, 01:48 PM | #17 | |
Rep 23
04-22-2014, 05:47 PM | #18 | ||
16
Rep 102
Shake & bake!!
04-22-2014, 08:23 PM | #19 |
11
Rep 77
i don't have paddle shifters. wish i did. i don't like to drive aggressive 100% of the time. drive mode is great when i'm relaxed. my problem with manual mode is i forget to shift, and realize rpm's are way high or way low. i older stick shift cars, it's easy to tell high rpm vs. low with sound.. but can barely hear a difference in this car. having it in sport allows it to shift for me so i don't have to forget. also, sport benefit isn't just shift points, it accelerates much easier with a light touch of the gas pedal than the drive mode.
04-23-2014, 10:13 AM | #20 | |
Rep 120
