Driver door lock
04-17-2014, 06:42 AM | #1 |
Rep 65
Driver door lock
Hi All,
I have a driver door which i cannot unlock with either key or keyfob. I checked the fuses and they seem fine. Should I upgrade the fuse to 20amp? My passenger door is good. Any ideas with problem? I think door actuator but maybe i missed something. Car: 320d 2006 e90 ES Thanks, Styvy |
04-17-2014, 11:47 AM | #2 |
douchebaggo
186
Rep 972
Very common issue. Check this thread on how to replace your actuator. Make sure to get the kit (p/n 51217263086) that includes both left and right for the price of one. I believe the dealer charges around $400 for each side. Definitely worth DIYing.
http://www.e90post.com/forums/showthread.php?t=477507 |
04-17-2014, 01:36 PM | #3 |
144
Rep 776
most likely the door actuator has a mechanical issue, it's a simple fix based on the link provided above...read through the DIY comments, ppl have posted links on where to get the parts for cheap
04-17-2014, 01:46 PM | #4 |
Rep 194
What others said. I had the opposite, mine wouldn't lock. New actuator fixed it.
2009 BMW 335i Jet Black - BMS Dual Cones, GP Thunder 7500k Fog's, Hellst XRT H8 AE, JB4 G5 ISO Map 5 -
2001 Cobra True Blue - Terminator Swap, 460WHP - |
04-17-2014, 01:55 PM | #5 | |
Rep 122
NEVER (EVER EVER EVER) "upgrade" a fuse! The fuse is there to protect your wiring and changing to a larger size fuse effectively turns your wiring into a fuse.
Simple example: Let's say you have a 15A fuse and the wiring can only handle 15A, but you upgraded to a 20A fuse. If 18A of current gets on that circuit due to a short other event causing a spike, your wiring will melt. If you had the 15A fuse, it would blow and you can just change it. Of course, my example isn't accounting for temperature variation and some safety factor in the design. Quote:
