Enabling DRL on 2007 335XI (E90?)
11-23-2007, 01:20 PM | #1 |
Rep 83
what is required to enable DRL on a 3007 335XI coming our of the US?
reprogramming, installation of relay or other? Thanks |
11-23-2007, 01:33 PM | #2 |
Ski bum
317
Rep 6,198
Without iDrive? It's done through the turn signal stalk. With the car on, but not started, depress the button on the end of the stalk, then use the rotodial on the stalk to move up and down. Use the button again to select options and make changes.
1999 e46 328i Ti Silver / Black[retired] 2007 e90 335xi Jet Black / Black[retired] 2011 e70 X5 35d Vermillion Red / Cinnamon 2011 e92 M3 LeMans / Fox Red extended |
11-23-2007, 01:38 PM | #3 |
418
Rep 12,276
^ what he said.
You might want to invest a few minutes reading this section of the manual - there are several settings you can select in the same menu tree. You might want to make a list of preferences and knock them all out at once.
I think it is bad luck to be superstitious |
11-23-2007, 02:12 PM | #4 |
Shawn
18
Rep 169
First you'd have to wait 1000 years. Then you should .
"Don't be scared of your potential to do great things."
11-23-2007, 02:28 PM | #5 |
31
Rep 324
Drives: Sparkling Graphite 2007 335xi
You can also find the manual in .pdf format online and then use the builtin search function!
Try this link below, registration may be necessary. https://oc.bmwusa.com/oe/ownersmanua...relID=1834001#
1987 Black on Black Mitsubishi Starion ESiR
2007 Sparkling Graphite 335xi |
