Rear differential issues?
04-16-2014, 09:11 PM | #1 |
23
Rep 197
I have an '09 335i 6AT x-drive with 64k miles. Tonight, the car started feeling funny around slow turns, vibrating a bit like something was slightly grinding and making a clicking noise every so often This primarily occurred when turning right, but happened once turning left (I did a series of tests around my neighborhood). It would also whine a bit under acceleration, almost sounding like someone with an aftermarket exhaust was coming up behind me. When I got home, it clunked pretty bad when shifting into R as well as D. Any ideas? Could it be as simple as replacing the diff fluid, or do you think it's a more serious issue? It's got me kinda nervous!
04-16-2014, 09:23 PM | #2 | |
51
Rep 719
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
04-17-2014, 08:05 AM | #6 |
34
Rep 1,093
When stopped the front axle is disengaged. So it is likely 1 of the rear CV joints. If there is play the open rear diff will let it clunk when you load the drive train.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
04-17-2014, 11:54 AM | #8 |
51
Rep 719
-Put the car on jack stands and manually spin each wheel. You should be able to duplicate the noise...
