Turbos need to be replaced, should I go non OEM?
04-15-2014, 10:31 AM | #1 |
Ez tur90
189
Rep 3,191
Dealer called me yesterday and they said I might need my turbo replaced. My warranty ended in January. Should I go non-OEM?
What are my options? RB Turbo? Will I need just the turbo upgrade? Will a stock (no engine modifications) car be able to handle bigger turbos, or do I need to upgrade more components? Should I just replace with OEM turbo? Err. I'm lost.
04-15-2014, 10:33 AM | #2 |
2095
Rep 43,350
I'd go with Vargas or RB. The cost to upgrade from the OEM's isn't that much and I know the RB's have a fix for the wastegates whereas the new turbos will eventually go back to being a rattle monster.
You should look into upgrading at the least the downpipes, FMIC & a tune if you're going to upgrade the turbos. |
04-15-2014, 10:46 AM | #3 | |
Ez tur90
189
Rep 3,191
PS. The car will probably never hit the track. Mainly used as a daily driver, and bi-weekly canyon runs.
04-15-2014, 10:49 AM | #4 |
34
Rep 1,093
^ VRSF. Great value for your money. Demand is high though but I bet Tiago can take care of you.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
04-15-2014, 10:54 AM | #5 | |
2095
Rep 43,350
If you're looking for a full set of bolt ons, we also offer a chargepipe and we're expecting our dual cone intake filters to arrive in the next couple of weeks. The chargepipe is recommended when raising boost levels since the OEM unit tends to fail pre-maturely and the intakes will allow the motor to breathe a bit better on the top end of the power band. |
04-15-2014, 11:45 AM | #6 | ||
421
Rep 1,643
2007 E92 335i MT
04-15-2014, 11:52 AM | #7 | |
27
Rep 199
04-15-2014, 12:20 PM | #8 |
1973
Rep 2,711
I'd be curious to see if it's possible to pass CA smog with upgraded turbos and stock everything else, or whether it's even good for the engine when untuned.
04-15-2014, 12:47 PM | #9 |
172
Rep 2,347
+1
I'd like to know this aswell,I plan on upgrading my turbos when they go and I'd hate to have to swap dps once a year.
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
04-15-2014, 01:13 PM | #10 |
161
Rep 3,736
I'm sure you probably know this but there is a BMW extended warranty on the OEM turbo's depending on your mileage. What's your mileage?
04-15-2014, 01:29 PM | #12 |
Rep 64
04-15-2014, 02:32 PM | #13 |
Ez tur90
189
Rep 3,191
67k
04-15-2014, 02:40 PM | #14 |
161
Rep 3,736
Dealer should get bmw to pay for new turbos, will cost you nothing, so just replace with new oem and enjoy
04-15-2014, 06:21 PM | #15 |
Ez tur90
189
Rep 3,191
Just got a call from dealer. Damaged Turbos are covered, vacuum hoses are cracked and not. So 500 something to have it replaced. I guess look at the glass half full. I just saved min 3k.
04-15-2014, 06:47 PM | #16 | |
2095
Rep 43,350
Should be in stock within the next 3-4 weeks
This would not conflict with any sort of emissions or inspection testing, they'd never be able to check if the turbos were OEM or not and the emissions portion shouldn't change too much either as long as you're tuned for it. Untuned you may run into problems running too lean on upgraded turbos on a WOT pull but idle/mid range low load should be fine. |
04-15-2014, 06:58 PM | #17 |
161
Rep 3,736
Being that you just came out of warranty in Jan, call the dealer back and see if they can get BMW to cover all expenses, worth a shot. Either way, yes you are saving thousands so that is good news.
05-06-2014, 08:24 PM | #18 | |
43
Rep 1,219
Is there a one-stop option or package to uprgade turbos that includes a tune, and associated mods. |
05-07-2014, 09:26 AM | #22 |
I even mod my cereal
247
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
^ This
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
