The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Noise from engine, and its not the oil filter
      04-14-2014, 10:25 PM   #1
cortega
cortega's Avatar
21
Drives: 2014 F13 M6
Hi, I recently got a 2006 e90 325i and its making a weird sound from the oil filter area. I tough it was the oil filter but after an oil change including oil filter, the sound is still there. Tonight I got a closer look, the sound is actually coming from between the oil filter housing and the engine block. I got no clue what could it be. Any help will be appreciated.
Noob here, tried to attach video but didn't worked for me
Edit: Got videos working!
      04-14-2014, 10:34 PM   #2
fravel
fravel's Avatar
1645
Drives: Monaco Blue '06 330i
Probably your oil filter housing gasket. That noise is air being sucked into your engine where the gasket has failed. Replace it sooner rather than later and also be sure to change your oil and your coolant, as you've probably now got oil in your coolant and vice versa. Do some searching on here, there are a lot of DIY's for this.
      04-14-2014, 11:06 PM   #3
cortega
cortega's Avatar
21
Drives: 2014 F13 M6
Didn't thought about it, will check, thanks!
      04-15-2014, 07:44 AM   #4
5tony
147
Drives: '21 M5/'15 X5 35i/'88 M3
Hard to say, but it could be a pulley bearing.
      04-15-2014, 12:26 PM   #5
mike3000fl
No_Country
138
Drives: 06 330i
probably the alternator.
take a big screwdriver, hold it firm against the alternator and other areas, the the handle against your eye. try to figure out where the noise is coming from. use the screwdriver as a stethoscope.
dont wear a tie, be careful not to get caught up in the running belts. dont die. im not responsible for your death if you do.
