04-12-2014, 12:03 PM | #1 |
102
Rep 775
Carbon Interior - My progress; Self made.
Hiyo.
I got a little bored as I am waiting for my OEM BMW Performance interior to arrive, I decided a few days ago I'd wrap my current OEM in carbon. I wanted to just try one piece, as this is my first time wrapping interior trim in carbon. First off, I am by no means an expert. I have played around with resins and fiberglass before and I figured I would give this a shot. I simply attempted with one piece first (driver side door handle) and currently still in the process. Started by taking the piece off and cleaned with dish soap. Sanded down with 120 Grit - 240 Grit Measured out the carbon. Gave my self an extra ~1" in each end. Getting ready to coat with black base coat Base coat applied, using a heat gun to get out all of the little bubbles At this point, I never took a picture of the carbon being raw. I had to relay the carbon due to me not letting the base coat sit long enough. This was after two coats of top resin and then sanding down the edges to make them flush with the piece. Test fitting, no clear coat and no sanding yet. This was simply to ensure everything fit without a problem. I've now just sanded down from 140 - 1600 grit. Wet sanding took place at 400 grit and up. I broke threw at one spot so I had to go and reapply resin and now I wait for it to dry. Once it's dry, I'll re sand that area and apply the clear... Stay posted.
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 Last edited by Cripple; 04-12-2014 at 12:58 PM.. |
04-12-2014, 12:41 PM | #2 |
***** noob
1355
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
I call you BS that its your first time ahahah
Thats impressive work You'll need some pro-grade clearcoat or its going to yellow over time
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
04-12-2014, 01:01 PM | #3 |
255
Rep 1,040
How did you remove the handle from the door? I read you pry from the bottom of the handle and work your way up to the top. Any plastic clips I need to be careful about in getting them to release?
04-12-2014, 01:05 PM | #4 | |
102
Rep 775
Started from the bottom with a trim pulling tool. Took a little force but work your way up slowly. I damaged one clip on the driver door but I put it back in and things are fine.
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 |
04-12-2014, 01:54 PM | #6 |
102
Rep 775
I can, you would just have to be responsible for shipping. I can pick the set up in North Dakota. Will take one week turn around.
04-12-2014, 04:56 PM | #7 |
Vrooom :)
313
Rep 2,602
OP this is really cool! Great job.
I may have to consider in the future, since I like the glossy CF interior a la new M3/M4, and the current one is more alcantera
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
04-12-2014, 06:18 PM | #9 |
102
Rep 775
I wasn't happy with how the first handle came out so I went for a go against my drivers door handle today while waiting for the resin to dry on the passenger one. Here is the step I took to ensure all the end are bonded to the surface of the original handle.
04-12-2014, 06:40 PM | #10 |
4515
Rep 8,942
That looks like it will turn out great, especially for a first time!
Slightly off topic as I realize it's a totally different process and not real CF, but figured those doing CF might have researched alternatives. Saw an old Wheeler Dealers w a Range Rover where they painted the trim black then floated a CF textured film in some sort of solvent and dipped the parts. Before I do a ton of research, anyone know the name of the process and/or if the results are any good? Looked great in TV but then again anything can look good on TV and look terrible in person.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
04-12-2014, 07:16 PM | #11 |
102
Rep 775
Wasn't entirely happy with this one either. We will see how this dries
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 Last edited by Cripple; 04-12-2014 at 07:25 PM.. |
04-13-2014, 12:21 PM | #12 |
102
Rep 775
Well today I sanded down that first coat of resin.
Applied second coat and now we look like this.
04-13-2014, 12:22 PM | #13 | |
51
Rep 99
Nice work, cripple!
http://www.hydrographicsinc.com |
04-13-2014, 01:20 PM | #14 |
Mr. Nice Says Hello
634
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
wow stunning!
04-13-2014, 01:30 PM | #15 |
102
Rep 775
Thanks guys... I hope I can wrap the centre one too my liking this week
04-14-2014, 06:33 PM | #16 |
102
Rep 775
Well I was going to clear these today but I went to final sand on both and I had a spot of carbon break threw. I knew I was really light on the top coats so I decided to put one more coat on both before getting ready to spray. Figured I would let you see them before I spray. This is only half the gloss the clear will have.
