New turbos, acceleration Wastegate rattle
04-12-2014, 09:10 AM | #1 |
Brian335tt
98
Rep 1,227
My situation is unique.
I used to have bad wastegate rattle in neutral or driving as the rpm came down I would get a rattlesnake kind of sound and it was seriously loud! So I ordered brand new twins off ticher with the updated 8mm wastegate. Now I only have wastegate rattle on acceleration, on throttle (50-75% throttle) my waste gate rattles, when I let go of the gas or rev in neutral I don't have any rattle. What should I do? Should I just get them adjusted at my mechanic? I'm worried they might start rattling like before on decel. New turbos shouldn't need to be adjusted so I'm kind of stuck on what I should do. |
04-12-2014, 10:07 AM | #2 | |
34
Rep 1,093
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
04-12-2014, 10:31 AM | #3 | |
45
Rep 676
// JB4 ISO // Running Meth // Full FBO // E85 user //
04-12-2014, 10:45 AM | #4 |
Brian335tt
98
Rep 1,227
Ya I bought them and had my local Indy do the install.
04-12-2014, 10:48 AM | #5 | |
Brian335tt
98
Rep 1,227
04-12-2014, 10:54 AM | #6 |
34
Rep 1,093
Yeah disconnect at the canister. You should cap the canister to prevent stuff getting sucked in. When test driving you might throw a code. When your testing the waste gate you can adjust if required it would be the same procedure.
04-12-2014, 11:01 AM | #7 |
Brian335tt
98
Rep 1,227
So if I disconnect both at the same time and the rattle is still there then what?
04-12-2014, 11:04 AM | #8 |
34
Rep 1,093
It's not waste gates then. Because they would be wide open = no flutter/rattle
04-12-2014, 11:07 AM | #9 |
426
Rep 2,136
First thing I did when I received my replacement turbos was testing them with a syringe to pull a vacuum on the actuator and see if the wastegate would close all the way before putting them on my car... The actuator may not be able to fully close the wastegate on yours because when it gets to 100% travel, the wastegate isn't properly seated...
If its coming from the rear turbo you can easily shorten the actuator rod from the top of the engine without having to remove anything. If the rattle comes from the front turbo, you'll have to pull it out of the car to adjust the rod... It may also be due to a vacuum leak. Have you checked all your vacuum lines from the vacuum pump to the canisters, and then from the canisters to the actuators for leaks? Connect a vacuum gauge on the vacuum line by the boost solenoids to see if you have enough vacuum to pull the wastegate closed. Idle vacuum should be around 16 to 18 in Hg. |
04-12-2014, 11:11 AM | #10 | |
Brian335tt
98
Rep 1,227
04-12-2014, 11:17 AM | #11 |
426
Rep 2,136
Was the wastegate closing all the way with full travel of the actuator arm?
I'm saying this because on one of the turbos I received, if I pulled on the actuator rod all the way, the wastegate would only travel like 95% of its range, and that would cause a rattle... |
04-12-2014, 11:35 AM | #13 |
426
Rep 2,136
U sure it's the wastegate and not a heat shield or something else? I had a rattle after I put everything back together and it turned out to be the clamp holding the catback exhaust. I forgot to tighten it up and my exhaust was rattling. Sounded like a wastegate.
04-12-2014, 11:38 AM | #14 |
34
Rep 1,093
I've never tried this test on this platform. I suppose it is possible for the rods to allow movement. I think gizmo is right and you need to adjust the actuators or you have a vacuum issue. I'd go back to the shop and explain whats going on and ask to get the stroke verified and adjusted.
04-12-2014, 11:39 AM | #15 |
Brian335tt
98
Rep 1,227
Well on jb4 on menu 12 on can slightly make it quieter but not much. And I already had a mechanic check heat shield and everything was good to. So now I'm just frustrated cuz I've spent so much money trying to find this noise and nothing. Where do I go from here now? Funny thing is it only happens under load, in neutral they don't rattle.
04-12-2014, 12:00 PM | #16 |
34
Rep 1,093
Thinking on this you had a trans issue also. I wonder if it's a cracked flexplate / loose Tq converter.
04-12-2014, 12:05 PM | #17 | |
Brian335tt
98
Rep 1,227
Tomorow I'm dropping it off for the adjustment. If it doesn't resolve the issue I'll check back either way |
04-12-2014, 12:34 PM | #18 |
426
Rep 2,136
With JB4 on map 8 (limp mode, wastegate fully open) do you still have a rattle?
Also, on map one, if you go to menu 2 and option 4 (hijack fuel gauge to show boost above, on or below target), the needle should stay in the middle when you WOT. If it goes to the left, you're not hitting target because of your wastegate not fully closed. |
04-12-2014, 12:36 PM | #19 | |
Brian335tt
98
Rep 1,227
04-12-2014, 12:47 PM | #20 |
426
Rep 2,136
04-12-2014, 01:23 PM | #21 | |
Brian335tt
98
Rep 1,227
As for the boost it kind of moved both ways under and over, it's unstable but at wot it goes over (just passes by one unit of halftank. Def doesn't stay in the middle. I can make a video and email it to you if you want. I can catch it on camera. |
