e90 320d Hesitant when accelerating lumpy noisy DPF Injectors turbo EGR ?
04-11-2014, 05:17 PM | #1 |
Rep 18
Hi
I have a 2008 BMW E90 320D M Sport with 48k on the clock. Car is hesitant when pressing the accelerator and its almost as if there is turbo lag etc. It hesistates around 3000 rpm when driving but then carries on as normal. I also had a funny smell coming from the engine bay and a BMW specialist said it was a DPF issue. I had the DPF knocked through which was blocked (it has not been mapped yet) and there is still lag when starting it and revving. I've cleaned the EGR valve as it was covered in soot (guessing from the DPF being blocked) and replaced the MAP sensor for a new one but still no luck. I've also disconnected the MAF sensor to see if it made any difference but nothing changed. No warning lights are on the dashboard. Would be grateful if anyone could help or shed any light or advice of similar problems they had. I've uploaded a video on youtube here of the noise and how it hesitates (please excuse the engine bay looking a bit untidy i had just put the EGR valve back quickly to test): |
04-12-2014, 03:26 AM | #4 |
42
Rep 825
04-12-2014, 04:29 PM | #7 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Check all seals in the pipe work after the turbo, and check the inlet manifold for leaks. As said though, it could a failing turbo.
Get it checked for fault codes, but turbos rarely give a fault code so just be vigilant.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
04-12-2014, 05:05 PM | #8 |
Rep 18
cheers guys. Im going to clean and check the swirl flaps and throttle valve next.
Then take the turbo off and actuator check the pipes and get the turbo and actuator sent away to be checked and repaired if need be. |
04-14-2014, 02:05 PM | #9 |
Rep 18
I removed the swirl flaps/inlet manifold today and it was covered with gunk - i've attached some pictures below.
I've also cleaned the throttle valve and going to re-assemble tomorrow. I've noticed where i removed the inlet manifold the inlet valves on the cylinder head are filled with gunk too does anyone recommend any good ways to clean this. Obviously i'm a little bit sceptical as it is part of the cylinder head and don't want to ruin the engine in any way (that's if it already isn't!! ) Pictures of the inlet manifold / swirflaps. The bubbles and white gunk are just the chemicals i was using to clean. Last edited by navc83; 04-14-2014 at 04:24 PM.. |
