help reading codes
04-11-2014, 04:03 PM | #1 |
93
Rep 1,644
help reading codes
My half check engine light came on few days ago after WOT it disappeared for a few days now its back on. I read the codes im getting: 20 (twenty & zero on the dash) 31(three & one) and 2A4 (20 100 40 on dash). I tried searching couldn't find anything thanks.
04-11-2014, 04:07 PM | #2 |
35
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Do you get Engine Malfunction, Reduced Power! message?
Check your charge pipe and lines imo. Something mighta popped or came loose at WOT. Does it feel like you're boosting ok? Not feeling sluggish is it?
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
04-11-2014, 04:46 PM | #3 |
93
Rep 1,644
Yeah thats what it is malfunction reduced power. No it doesn't feel sluggish. But when I step on the gas it is sluggish when the lights on. When I turn the car off and back on it disappears and drives just fine.
04-11-2014, 05:42 PM | #4 |
35
Rep 1,652
Sounds like a vacuum leak under higher boost pressure. Happened to me but it was an easy diagnosis cause my charge pipe basically exploded on one end. The cp is on the driver side under the airbox. You should see if it looks OK from both ends. The end by the throttle body is hard to see w/o removing the airbox though. That's where mine went bad.
my CP woes
04-11-2014, 05:50 PM | #5 |
89
Rep 3,732
Drives: BMW S1000XR
When I had a boost leak(@ cp) I could boost up to 9-10 psi, but it would fall flat soon after when I had Cobb Stage II. When I had injector issues the half engine light would turn on, loss of power, and a bit of shaking would occur as soon as I went WOT. The half engine light would not return unless I went WOT again. GL! always fun to figure out
BMWCCA member |
04-12-2014, 01:21 AM | #6 | |
93
Rep 1,644
