BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Performance exhaust for F20 116i ?
      04-11-2014, 03:52 PM   #1
bennzwel
21
Drives: 2013 F20 Edition 30
Question Performance exhaust for F20 116i ?
Hi all,
During my research about the difference between 116 and 118 (F20), I realised the only major difference is the Exhaust which seems to be at the last section of exhaust system ( correct me if I'm wrong)
So I am thinking at some point and time upgrade my exhaust to something that improves the performance and adds a bit of sound character to the car.
Definitely don't want to sound too loud or absurd, but just something that has some depth and sportiness sound without being too loud or annoying.
Do you have any recommendations ? Would one pipe exhaust tail be sufficient or should I upgrade to dual pipe ( and somehow cut the bumper part to allow two pipes) ?
Appreciate any suggestion
      04-11-2014, 04:00 PM   #2
ovekvam
Norway
266
Drives: 2021 Galvanic Gold i3S
I haven't done research on the parts involved myself, but I have read the conclusions from others who did, and they mentioned that the downpipe was different between the 116i and 118i.
      04-11-2014, 04:14 PM   #3
bennzwel
21
Is the down pipe the last section after the silencer? I guess changing that part only won't be sufficient as the silencer exit would be the small diameter as well.
I would like to hear from those whom made the change in exhaust and actually felt any difference.
Cheers
      04-11-2014, 04:28 PM   #4
ovekvam
Norway
266
No, as I understand it, the downpipe is right next to the turbo.
      04-11-2014, 04:35 PM   #5
bennzwel
21
Ahh. Thanks for the clarification !
So is that part replaceable ( without welding ) ?
      04-11-2014, 04:37 PM   #6
ovekvam
Norway
266
I would think so, but I have never replaced it myself.
It is probably rather expensive.
      04-12-2014, 03:28 AM   #7
lefthander
14
Drives: BMW F30
Use realoem.com doing a quick comparison, the downpipe is the same but the centre and rear pipe is different.
      04-12-2014, 03:54 AM   #8
ovekvam
Norway
266
Yes, indeed. I also checked it myself now. All except for the downpipe is different. Always better to check yourself than believing others.
      04-12-2014, 04:07 AM   #9
bennzwel
21
Thanks for the link. Quite useful.
So would it worth to change that section with a performance exhaust? If so what is a good replacement in terms of power increase and better sport class engine noise (something deep but not overally loud or noisy )
      04-12-2014, 05:36 AM   #10
vladberca
vladberca's Avatar
Romania
763
Drives: '18 octavia 2.0 tdi dsg
Supersprint with downpipe
      04-12-2014, 06:31 AM   #11
bennzwel
21
Thanks , I actually looked at their site and their products seems decent.
I thought down pipe was not the issue?! And the rest is restricting the 116i engine
      04-12-2014, 11:00 AM   #12
Callthecops
Belgium
Drives: F20 118i
The downpipe is the most restrictive factor in your 116i compared to the 118i.
The Supersprint downpipe is a catalytic converter with a 200 CPSI unit. (1686 euro incl VAT).
This means that your engine can exhale a little better than with the stock downpipe.
This is a good thing....but don't expect a lot more HP or torque.
The only thing that will improve is the sound.
When you want more power you need a powerbox (Racechip, Hartge, AC Schnitzer, etc).
      04-12-2014, 11:29 AM   #13
lefthander
14
Drives: BMW F30
I think the final drive between 116 and 118 is different too but I can't comment as it's too technical for me. Lol
      04-12-2014, 12:06 PM   #14
ovekvam
Norway
266
But we just found that the downpipe in the 116i and the 118i is the same. It has the same part number on RealOEM.
      04-12-2014, 02:12 PM   #15
Callthecops
Belgium
Drives: F20 118i
I missed that part.
So the 116i has the same exhaust flow rate as the 118i, but the rest of the exhaust is different (restricted)?
Strange because during my education it's was the rule that turbo engines (with adjustable valves) had the restriction factor as close to the turbo as possible.
I'm still confused.
      04-12-2014, 05:04 PM   #16
bennzwel
21
We need some expert to enlighten us about this exhaust comparison and to see if there is an actual benefit gained by replacing it ( parallel to using ACS tuning box )
      04-16-2014, 05:19 PM   #17
bennzwel
21
Any more suggestions for the exhaust upgrade which adds better sound and performance increase compared to the stock exhaust ?
      04-17-2014, 02:04 AM   #18
ovekvam
Norway
266
The stock BMW exhaust systems are pretty good, making it difficult to add performance gains by swapping it to something else. I guess you could gain a little by installing the 118i exhaust.
1addicts
