2009 335i issues - are they a concern?
04-11-2014, 09:31 AM | #1 |
30
Rep 373
I picked up my 2009 335i with x drive 6 speed manual, love it.
Now that winter is over, I am noticing a few things though: 1) loud ticka ticka, just like a diesel. I've had other german cars that do this, but this seems louder then those. It's also after warm and at oil temp. 2) roughish idle at start up occasionally. It'll fluctuate between 650-850 RPM, then once warmed a bit, it'll idle at 750~ pretty solid, is this a concern? My mind is stuck on that I might have a leak in the turbo system somewhere? No CEL |
04-11-2014, 09:42 AM | #3 | |
129
Rep 1,052
2. My 328 does this too. Clears up and is fine. Last time I spoke to my BMW Master Tech he said it's common and expected on a variable valve motor.
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White |
04-11-2014, 10:48 AM | #5 |
214
Rep 988
Also maybe try another type/brand of the variety of approved oils. If this is in fact lifter tick I'm surprised you were not hearing it during the colder temps, I had some lifter tick that went away when it got warm.
04-11-2014, 11:22 AM | #6 |
30
Rep 373
That is my guess, lifter ticket ... i've heard it before in my 1.8T's, 2.0T's, etc. It just sounds louder!
I will drive, it will not be heard, i'll idle for a few seconds, then it will come back. This was happening when it was cold as well. I get my oil changes at the dealer still ... I got a few coupons, I think they're using castarol now. I have 72k on the clock. Oil levels look good as well. |
04-11-2014, 11:25 AM | #7 |
Rep 212
Drives: 2007 E90 328xi
I talked to a BMW tech, temporary fix on the lifter noise is to run the engine at about 4k revs while in park. It helps circulate the oil. He says it's mostly just an annoyance thing, not an actual harmful problem.
04-11-2014, 11:27 AM | #8 |
30
Rep 373
That's all I wanted to make sure ... it sounds like metal on metal, so I always get worried ... wanted to make sure the N54 was OK with that noise too.
04-11-2014, 11:27 AM | #9 |
7478
Rep 10,120
The ticking you sometimes hear on a 335 is from the fuel injectors they are a bit noisy. This is not a problem. On the other hand the ticking on a 328 is a sign that the lifters are not getting enough oil and NO this is not normal. I had the head and lifters replaced in my old 328 to fix the issue. The ticking on a N52 will not break the car but will increase wear and tear on the engine a bit.
04-11-2014, 11:28 AM | #10 | |
30
Rep 373
I should get a db reader and see if it's coming from the injectors or the lifters. |
04-11-2014, 11:29 AM | #11 |
72
Rep 1,181
Sometimes oil shops will do the recommended 6.5quarts and send you on your way. Not knowing how the N52 is on oil but the N54 sometimes requires the full 7 mine did any way ( after doing my own oil change and driving 10 miles my oil light came on saying low oil I put the left over oil .5 quart and it went away Mobile1 0w-40) Lifter noise is apparent when I first start the car but goes away after driving. I do notice when they get oil on them they are less noticeable, parking at angles makes them sound like a diesel truck motor
_Sinister_
04-11-2014, 11:30 AM | #12 | |
30
Rep 373
04-11-2014, 11:34 AM | #13 |
7478
Rep 10,120
04-11-2014, 11:36 AM | #15 |
56
Rep 1,464
Drives: 2009 BMW 335xi
Almost definitely the injectors. If you take the engine cover off it sounds like a diesel especially when cold. Neither of the things you mentioned are issues to worry about. Just drive it.
04-11-2014, 11:37 AM | #16 |
33
Rep 655
search on here for lifters issues, just recently someone else was posting something about that and yet, not a normal thing, yes first solution is to try to lubricate the lifters by revving the engine but eventually replacement will have to be done, in the other post someone even made the link to some BMW internal document where they talk about it. I would make a dealer aware that some noise is present, might play in your fav later on
04-11-2014, 11:38 AM | #17 | |
30
Rep 373
04-11-2014, 11:51 AM | #18 |
72
Rep 1,181
Without hearing your noise I wouldn't be able to tell but my noise is definetly the lifters if your having idle issues where it runs fine after engine is warmed up might be your injectors.
_Sinister_
04-12-2014, 12:48 AM | #20 |
68
Rep 639
Drives: 11 E90 328i
Its impossible to tell without hearing it, but direct injected engines (of which the N54 in the 09 335i is) do have a ticking sound to them.
04-12-2014, 03:46 PM | #21 |
Rep 41
Drives: 2007 335i E90
Yeah just drive it. That is how I learned to deal with any issues with this car. If it still pulls hard, and sounds like a machine when I mash it, I'm all good. This goes against my natural way of thinking with cars. I tend to baby this one compared to my G8.
04-12-2014, 04:07 PM | #22 |
89
Rep 3,732
Drives: BMW S1000XR
It's your injectors as some have pointed out. The lifter/tappet noise is specific to the N52 ONLY.
BMWCCA member |
