2006 330i Rough Idle
04-10-2014, 12:19 PM | #1 |
Rep 10
Long time reader. First post...
I have been trying to diagnose a rough idle on start (cold or hot) for several months. The car has 115000 miles on it so I have been replacing things as I go. So far I have: Replaced both Vanos Solenoids Replaced CVV (oil separator) and all hoses Replaced all spark plugs Replaced all coil on plugs Cleaned the MAF sensor Replaced upstream O2 sensors Replaced Eccentric shaft actuator (motor) Ran two bottles of Chevron Concentrate Plus Fuel Injector cleaner through (not at same time) When cold or hot when first started it "hunts" from 800-1200 RPM. It seems that once the "choking mechanism" is opened/deactivated/etc. it will idle like a swiss watch at about 600 RPM. Runs great other than the idling problem. Any ideas what to look at next? Thanks! Last edited by mteel; 04-11-2014 at 07:39 PM.. |
04-10-2014, 12:22 PM | #2 |
72
Rep 1,181
IDK for sure but maybe time for walnut blast
Check this link OP http://www.e90post.com/forums/showthread.php?t=682116 ^
_Sinister_
04-10-2014, 02:47 PM | #4 | |
Rep 10
Any other ideas for things I can reasonably do? |
04-10-2014, 03:17 PM | #6 |
Fuck it dude, let's go bowling.
888
Rep 2,480
Doesn't intake walnut blast only apply to turbo-charged cars?
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
04-10-2014, 04:28 PM | #7 |
964
Rep 3,854
Drives: 330i, 135i
I am almost positive you have a leaky injector.
04-11-2014, 07:24 AM | #8 |
888
Rep 2,480
Would this settle after warm-up?
04-11-2014, 07:31 AM | #9 |
103
Rep 2,783
See my sig below.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
04-11-2014, 11:21 AM | #12 |
964
Rep 3,854
Drives: 330i, 135i
If you have not troubleshooted for injector leaks, it's best to pull all of them and service each one. If you can DIY see below:
In order to access them, first pull your fuel pump fuse and run the car til it dies. Then you'll need to get all the basic stuff out of the way and remove the injector harness, which is quite a pain in the arse. Once you've exposed the rail in it's entirety, there are two 10mm nuts and nothing more. Leave the clips that hold the injectors to the rails and give them a tug. Don't fear them. They won't break and the rail won't bend. Now position them in a low plastic container to catch any gas that remains in the line. Pull the clips and remove the injectors. You are now ready to service them with an appropriate kit. |
04-11-2014, 11:24 AM | #13 |
964
Rep 3,854
Drives: 330i, 135i
Not quite, A while back, some one posted that have been having warm start up issues. Namely, when he start the car for the first time of the day everything was fine. However, after the car was driven then turned off and sits for over 30 minutes it would not start on the first crank. It starts on the second attempt, idles rough, He would hit the gas and everything was ok but still rough idling due to a leaky injector.
04-11-2014, 11:32 AM | #14 | |
Rep 10
I can DIY and servicing the injectors sounds like a good idea anyway. Any links to point me to for doing it? Thanks again. |
04-11-2014, 02:36 PM | #15 |
19
Rep 278
Any codes stored? If so, is it a 1-2 cylinder misfire or multiple cylinder misfire? That will eliminate a few things.
I forgot whether there's an ICV on n52. If there is one, check it. Also, did you check for vacuum leaks? Theoretically it would be worse when the engine is cold.
04-11-2014, 03:24 PM | #16 | |
41
Rep 642
and http://www.amazon.com/Chevron-67740-...ywords=techron Not really the same thing. Which did you run two bottles of? One is very low % of PEA (polyether amine) meant for maintaining an already clean fuel injectors/system and the other is up to 32% PEA meant for cleaning a dirty system followed by an oil change. I'd go with 3M. It supposedly has 40% to 60% PEA http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 If it doesn't help, I'd also remove the injectors and bath them for a while in the 3M stuff and if you can, cycle it through the injectors. Not sure on the process, totally research cleaning injectors before doing it. |
04-11-2014, 04:57 PM | #17 | |
Rep 10
04-11-2014, 05:02 PM | #18 | |
Rep 10
04-12-2014, 12:29 AM | #19 |
68
Rep 639
Drives: 11 E90 328i
How old is your battery? Sounds like a silly question, but I had similar problems on my 06 325i for like a year before my battery finally gave out. New battery, and it idles much smoother after start.
04-12-2014, 09:00 AM | #20 |
Rep 10
I have no idea - I bought the car about 18 months ago. Cranks just fine first thing in the morning.
04-12-2014, 11:40 AM | #22 | |
24
Rep 469
Tags |
330i, rough idle |
