Failed CA Smog: High Hydrocarbon PPM on n54 2007 335i e92.
04-09-2014, 10:20 PM | #1 |
20
Rep 95
I just recently got back from an emissions test, CA SMOG, and received a high reading on HC (PPM): hydrocarbon ppm. The results are as follows:
I have a n54 2007 BMW 335i with JB+ installed when the first test was taken. Test 04/09/2014 FAIL • 15MPH: 96 PPM (MAX Allowed: 52) • 25MPH: 28 PPM (MAX Allowed: 36) Test 04/10/2014 FAIL • 15MPH: 58 [-38] PPM (MAX Allowed: 52) • 25MPH: 36 [+8] PPM (MAX Allowed: 36) Changes: Warmed up cats for 30 minutes, almost passed 15mph measurement which failed; almost failed 25mph measurement this time though. Test 04/12/2014 PASS • IDLE @ 732 RPM: 92 (Max: 100) • Neutral @ 2500 RPM: 68 (Max: 130) Changes: Added the CRC Guaranteed to Pass Fuel Formula; Plugged in vacuum connector that was previously removed for exhaust sound mod; Drove car for longer distance, kept car running @ smog shop. Smog shop also performed an idle emission test compared to dyno. Conclusion: I've just barely passed, it could be anything. Not sure if the fuel additives helped, I haven't run through the whole tank before retaking test. The test I've taken this time was also an emissions test from idle, as compared to the dyno/speed tests, not sure if that was the case. Just glad to have passed, not looking forward to 2 years later though. Work Log (prior to test): I didn't warm up the engine other than driving 2 miles to a shop before taking the test. Switched back downpipes to OEM stock from AR Catless 2 weeks before test. I've just (1 hr before test) put in the stock intake from AFE. 4/10/2014: Removed JB+ Chip, warmed up cats for 30 min; results still fail but 15mph test closer and 25mph test worsened. View post on imgur.com 4/12/2014: Added 'CRC Guaranteed to Pass fuel additive formula'; Plugged in vacuum actuator connector from sound mod; Drove longer distance to warm cats; Passed on idle based emissions test compared to dyno. My question to you is: What do you think is causing the high HC PPM? Would having JB+ plugged in make a significant difference in hydrocarbon compared to a stock install? I forgot to unplug the chip before taking it in, I wonder if it'd make a difference if I remove the HB+ chip. Last edited by Curt; 04-12-2014 at 09:32 PM.. |
04-10-2014, 10:00 AM | #2 |
just another bmw douche bag
195
Rep 3,640
you probably didn't get the cats hot enough to work properly.
Does the JB4 have a bypass setting? that should be fine for testing. Also, when you change engine mods, it can take a couple hundred miles for things to adapt, so maybe the car didn't have enough time to adapt back to the stock airbox. keep driving your car with the stock stuff for a few days, and when you are ready to re-test, drive the car around for 30 minutes before pulling into the smog shop. |
04-10-2014, 10:37 AM | #3 |
1911
Rep 13,104
Cabon Build up in on Intake Valves?
Just speculation but maybe its time to have it Walnut Blasted. |
04-10-2014, 11:40 AM | #5 |
453
Rep 2,973
I don't think carbon buildup. My car needed head work and still passed.
If the cats are not warm, forget it. 2 miles of driving before a smog test? Are you kidding???? 2 miles, the car has not reached operating temp. You still might be running rich from starting after two miles. The smog station should have sent you on your way and not even done the test! The cats need to be properly heated. The car needs to be at operating temperature. Drive for 30 minutes before testing. If the cats are hot and all emissions stuff is intact and the car is at operating temp, failing is not likely.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
04-10-2014, 11:42 AM | #6 |
215
Rep 1,818
Yup, failure at low means the car wasn't hot, at higher speed it was fine. You need to give it some good heavy load runs to get the cats hot and slap it right on the rollers.
04-10-2014, 01:32 PM | #8 | |
20
Rep 95
Naa, I've had valve cleaning a few hundred miles ago. |
04-10-2014, 11:56 PM | #9 |
20
Rep 95
4/10/2014:
Removed JB+ today and warmed up cats/car for 35 min, 4-5th gear 80 mph runs. Results still fail but HC @ 15mph better, 25mph worsened. new results(hot engine w/o chip) compared to new results(hot engine w/o chip) compared to View post on imgur.com Next up: Going to reset battery since I pulled chip, put in some emissions test formula/fuel system cleaner ( pic1 pic1 View post on imgur.com ) and run the tank through before going to next smog, will post results.. Any more suggestions? |
04-11-2014, 01:08 AM | #10 | |
38
Rep 208
In my case, my first attempt at smog check I left in my BMS DCI and just disabled my JB4 (left installed) immediatly before I went on the rollers. I passed emissions, but failed readiness test because my car needed to drive around on stock configuration for a while. The technician was nice enough to pass my DCI even though he wasn't supposed to because they aren't CARB certified. I came back a week later driving on Map0 (JB4 disabled) and stock intake for about a week and passed every test with flying colors. Good luck!
AW E92 M3 DCT /// |
04-11-2014, 01:11 AM | #11 | |
20
Rep 95
I just realized that when I replaced my tail lights in the past, I realized a cable was disconnected from previous owner. I realized this is the exhaust sound mod, alternative of golf tee mod. http://www.e90post.com/forums/showthread.php?t=80661 Could having that cable disconnected be the root cause? I'm pretty sure it is now so I'll reconnect it tomorrow and drive up to SJ for maybe another test. I already put the emissions formula fuel additive in the car. |
04-11-2014, 01:54 AM | #12 |
38
Rep 208
You're welcome.
The exhaust flap mod or whatever the kids are calling it nowadays probably doesn't have anything to do with pass/failing. BUT I did connect mine before my test just to make sure. Go ahead and plug it in. Couldn't hurt anything.
AW E92 M3 DCT /// |
04-12-2014, 02:18 PM | #15 |
Rep 50
Smog techs are not created equal. Perhaps you might wanna take it to a reputable smog shop. All Smogs in Dublin is excellent. My mechanic recommended them to me a while back. Brad is very knowledgeable when it comes to emission testing. You can ask him to run pre-test to determine wheter or not you'll pass prior to performing an actual test. I'm not at all affiliated, just a very satisfied customer.
04-12-2014, 03:41 PM | #16 | |
20
Rep 95
04-12-2014, 04:34 PM | #17 |
Rep 50
04-12-2014, 05:17 PM | #18 |
89
Rep 3,732
Drives: BMW S1000XR
Frickin CA. GL OP!
BMWCCA member |
04-12-2014, 09:30 PM | #19 |
20
Rep 95
Conclusion: I've just barely passed, it could be anything. Not sure if the fuel additives helped, I haven't run through the whole tank before retaking test. The test I've taken this time was also an emissions test from idle, as compared to the dyno/speed tests, not sure if that was the case. Just glad to have passed, not looking forward to 2 years later though. |
11-06-2014, 10:29 PM | #20 |
14
Rep 125
Golf Tee Mod Emission test result in california
Hi fellow Beemers
Has anyone done golf tee mod either old method or unplug the wire in the trunk and went for california emission test? Did the test pass or fail? advise please. |
