2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum 2 Series Photos and Videos Installed Black M Performance Grills Tonight on my MW M235i
      04-09-2014, 09:03 PM   #1
PigWig
56
Drives: 2019 BMW 330i X-Drive
So I installed the M Performance grills tonight. I took the easy way out by cutting one of the slats of the OEM grill. If you do this right, this is a 10 minute install and you preserve the OEM grill (although one slat has a non-noticeable cut in it).
All you need for this install is something capable of cutting through the lower border of one of the grill slats. No bumper removal necessary, and you don't even need to unbolt the bumper.
Before shots:
I made a cut here:
I then reached my hand through the hole as I bend the slat out of the way, release the 7 brackets, and the kidney pops right out:
Black pops in:
Same on the opposite side:
Completed project:
Appreciate 2
      04-09-2014, 09:09 PM   #2
rSplines
rSplines's Avatar
Drives: 2014 M235i
much better over stock
current:
2014 BMW M235i Black on Black
2012 BMW F800R
sold: 2004 Dodge SRT-4, 415whp 416wtq
      04-09-2014, 09:27 PM   #3
BEM-S4
BEM-S4's Avatar
4515
Drives: Dinan M235, Dinan Sport Wagon
Looks great huge improvement. Since you went through the grille, do you think it would be possible to skip the cut and undo the clips with one of these tools? Otherwise could you easily fit your hand in there? Seems pretty tight.
http://www.amazon.com/gp/aw/d/B000FB...=ATVPDKIKX0DER
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      04-09-2014, 09:45 PM   #4
prolif1k
54
Drives: 2018 Fashion Grey F80
I simply undid the screws on the bumper under the weather guard, pulled the bumper out a bit, and slid my arm down behind the bumper to pop them out. If your forearms are big, though, I don't see this being a possibility. My arm was just barely small enough to do this, though so YMMV.
      04-09-2014, 10:15 PM   #5
BEM-S4
BEM-S4's Avatar
4515
Seems like a nice job for my 2 year old niece
Was getting the bumper back / aligned properly an issue? Any play in the screws?
      04-09-2014, 10:32 PM   #6
webdither
59
Drives: 2014 BMW M235i
Once you get one of the grills out resist the urge to pop in the new one and use the opening you made on one side to remove the other grill on the other
2014 M235i | Manual | Estoril Blue / Terra | Tech, Premium, HK Audio, & Driver Assist | M Performance Exhaust, Stainless Steel Pedals, Black Kidney Grilles
Euro Delivery Trip Report
Appreciate 2
      04-09-2014, 11:53 PM   #7
h0pe
Drives: M235i
beautiful, this would be the first mod i do
      04-10-2014, 04:16 AM   #8
Delnari
Delnari's Avatar
255
Drives: 2014 MG F22 Auto
After looking and reading more about the procedure letting one of the OEM grills to be sacrificed for the cause is the easiest way to go here. Guess we can put the good one left after change up in the classified area for those who will need to return back to stock.
      04-10-2014, 07:05 AM   #9
basiluf
77
Drives: 2019 S450 2018 S90
Yup. A 10 minute install should only take me 45 minutes, which is fine. Now I just have to see them on a MG 235 first.
'14 M235i(current)ED
'11 E93 M3(past)ED
'08 E90 328i(past)Local
      04-10-2014, 07:13 AM   #10
prolif1k
54
No, the bumper was easy peasy to get back in alignment.
Honestly, it's worth a shot. The bumper can be pulled out a lot more than you initially think. I'm used to having to remove the entire bumper to swap the grills on my old car, a Volvo C30. THAT was a pain.
      04-10-2014, 07:23 AM   #11
creepy coupe
creepy coupe's Avatar
1867
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
There was barley a 2" gap when I undid mine. No chance of getting my arm in.
Current car.M240i.
Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci.
      04-10-2014, 07:42 AM   #12
bman6074
103
Drives: 14 M235i and 07 Lotus Exige S
I can't imagine this is much different then the 135i. The slots when the grill is out look exactly the same.
DIY's for grill replacement
http://www.1addicts.com/forums/showthread.php?t=210582
      04-10-2014, 07:46 AM   #13
prolif1k
54
You can definitely make much more than a 2 inch gap, trust me. You have to pull the bumper up and out after you slide it out of the slot it's in. I had my friend hold it in position, but I probably could have done it by myself.
      04-10-2014, 08:06 AM   #14
PigWig
56
It might be possible, but it would take a lot of patience.
I'll also add, the picture I included of where I made the cut is after the slat has been cut. If you simply cut the bottom portion and bend the slat out of the way, you can leave the top attachment in tact. If I needed to go OEM for any reason, I could pop the chrome ones back in and nobody would be able to tell they were even cut (of course, I would know). Make a nice clean cut at the bottom only and you should be good.
      04-10-2014, 08:07 AM   #15
PigWig
56
I tried this method on my F30, but I ended up with two broken brackets in the bumper cover. I wanted to absolutely ensure preservation of the bumper cover brackets this time, even at the expense of a cut in the OEM grill.
      04-10-2014, 08:52 AM   #16
creepy coupe
1867
2009 335i  [0.00]
Same here I wasn't going to risk a new bumper for the sake of a grill I was never going to use again.
Current car.M240i.
      04-10-2014, 10:50 AM   #17
Delnari
Delnari's Avatar
255
Agree. If you have no need to keep the original grills cut them out. For us leasee people it would be nice to have a working procedure to recover the grills in order sell the black ones later.
      04-10-2014, 12:29 PM   #18
BEM-S4
BEM-S4's Avatar
4515
If you decide to cut your grille PM me. If I have to do the same I'll cut the opposite side I'm going to turn mine back in with performance grilles. Can work out a deal so you have a complete set if you want.
2022 Macan S
      04-10-2014, 12:40 PM   #19
Delnari
Delnari's Avatar
255
Sounds like we can have people put their old grills up in the classified section for us needing them down the road.
      04-10-2014, 12:54 PM   #20
BEM-S4
BEM-S4's Avatar
4515
Yes, although hopefully not everyone will destroy the same side.
      04-10-2014, 01:37 PM   #21
Ryan@IND
Ryan@IND's Avatar
1763
Drives: ACR
The black kidney grills completely change the look of the front. Nice work!
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      04-10-2014, 01:49 PM   #22
BEM-S4
BEM-S4's Avatar
4515
I really think black grilles, your painted reflectors and some stealth turn signal bulbs is the best look on most if not all colors. Huge impact for small dollars.
2022 Macan S
Search this Thread:
Advanced Search
2addicts
