Hex Head Broke on to Shock Shaft! Help!
04-09-2014, 08:30 PM | #1 |
Boooost!
70
Rep 793
Drives: 335i
So I was removing my shocks to install better bump stops, when I put my open then wrench on the nut and used my ratchet to tighten the hex head of the shock shaft it broke!
Somehow I accidentally forgot to put the retaining cushion guard back in but it goes right before the top nut and washer. I tried using a dremel to cut a slit in the top of the now broken shaft top to get a flat screw driver in there, too tight I cant get the nut off! Do I have any other way to do this?
JB4 Stage 2 | Injen CAI | BMW PE | AR Catless DP | Alpina TCU Flash | Eibach Pro Kit | Custom TCKline Koni's | 19" M359 Wheels | DWS Tires |
04-09-2014, 09:18 PM | #2 |
687
Rep 2,770
Impact driver should be able to crack the nut loose. Then it is time for a new shock.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
04-09-2014, 11:20 PM | #4 |
Boooost!
70
Rep 793
Drives: 335i
I just cut the top slit deeper and wider. Wedges a flat piece of steel in there. Broke the nut loose.
I had to cut the bump stop type washer cushion and then slipped it around the shaft and torqued the nut probably less than it should but its snug. The nut will not be able to ever come off now. So when I get new shocks next time I will have to cut the shaft behind the wheel LOL All seems ok now. Just had to rig it up.
05-26-2015, 08:44 AM | #5 | |
81
Rep 228
Drives: E92 07 335i
Right now I'm planning to dremel the top mount nut and replace the mount - gives me reason to go with the dinan upgrade. |
05-26-2015, 10:03 AM | #6 |
4276
Rep 9,209
pull the bushing and dust cover down and grab the shock shaft with vise-grips
