DSC Malfunction
04-09-2014, 03:10 AM | #1 |
224
Rep 699
DSC Malfunction
So my car has been having an issue where it pulls to the right. I just got camber arms, toe arms put in on top of having pss9's all around. I decided to get the car corner balanced and aligned. While leaving the alignment shop and getting onto the freeway I noticed my car steers straight only when the steering wheel is 20 degrees to the right. About 10 min into my drive my DSC malfunction light illuminates along with the DBC, and startup assistance malfunction. Now before everyone refers me to replacing the steering angle sensor or cleaning it, I don't think it is the culprit since the timing was a little odd (right after a corner balance/alignment.) I was wondering if anyone could chime in their thoughts. Thanks!
04-09-2014, 03:44 AM | #2 |
28
Rep 321
If the DSC light is on, it could be one of the wheel speed sensors that's been knocked / unplugged (insert other possible things a mech could have done)
Get a cable plugged in to INPA: you'll be able to see what the steering angle sensor is reporting (It's incredibly accurate), and you'll be able to see if any of the wheel speed sensors are reporting bad. Relatively cheap to fix and you can do this yourself with relative ease |
04-09-2014, 08:04 PM | #5 |
224
Rep 699
It wasn't an intern, he aligns porsche race cars so he knew what he was doing, or so I thought. I took it to pep boys and saw that the alignment was way off. The car was then re-aligned, i reset the battery did the lock to lock bs and plugged in my bt tool and cleared all the modules, reset the steering angle sensor and the light is still there.
04-09-2014, 08:23 PM | #7 |
224
Rep 699
04-09-2014, 10:50 PM | #8 |
224
Rep 699
So i was just cornering the car and was powering out of a corner and the rear started to begin to get squirly and the traction light flashed once then all the codes disappeared.
04-26-2014, 12:08 PM | #10 |
11
Rep 172
I had the same 3 errors after a rear wheel flat and just popped the clutch and gunned it for a second and after the tires spent and traction light flashed, errors cleared.....
2011 E93 335is / BSM / Coral Red / 6MT / NAV / HK L7 / BSW Stage One / SWS8's
1994 E32 740iL / Black / Black 2008 E85 Z4 / Stratus Grey / Dream Red *SOLD* / 2006 E90 325i / Jet Black / Black *SOLD* / 2001 E53 X5 / Silver / Grey *SOLD* |
