Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Sidemarker Delete during Welcome Lights
      04-04-2014, 02:15 PM   #1
Wycy
Drives: 2011 BMW 328i xDrive
Here's how I coded the sidemarker delete for welcome lights on an '11 E90.
In the module NFRM, set WL_FRA_V to nicht_aktiv.
Before:
View post on imgur.com
After:
__________________________________________________ ___
Original Post
I successfully coded out my sidemarkers during normal driving by setting SIDEMARKER_US to nicht_aktiv in NFRM. I also changed WL_SL_2_3R from soft_einschalten to nicht_aktiv, but the sidemarkers still fade on for the welcome lights. Any thoughts? Did I do this wrong?
Edit: also, I accidentally set WL_POL_3R to nicht_aktiv initially when I confused cornering lights and sidemarkers. But doing this ended up disabling the angel eyes for some reason. I set POL back to soft_einschalten.
      04-04-2014, 02:46 PM   #2
deeLow
DOPE
deeLow's Avatar
148
Drives: F80
Can't remember the code exactly, but it was also on of those WL_ lines.
IIRC, it was short, began with WL and ended in either V or H, or both.
      04-04-2014, 03:18 PM   #3
joepcrepairs2
joepcrepairs2's Avatar
16
Drives: e92
SET TO NICHT AKTIV
WL_SL_2 or WL_SL_2_3R)
      04-04-2014, 03:30 PM   #4
Wycy
Originally Posted by ************* View Post
SET TO NICHT AKTIV
That's what I tried with WL_SL_2_3R :\ I don't have just a WL_SL_2.
      04-04-2014, 04:13 PM   #5
joepcrepairs2
16
Drives: e92
this to nicht aktiv also
WL_BLK_V
      04-04-2014, 04:33 PM   #6
Wycy
WL_BLK_V
Unfortnately, I don't have that line. :\ I do have a WL_BLK_V_MIN_PWM, however, which is currently set to wert_01. Thanks though, I do appreciate the help!
      04-04-2014, 05:26 PM   #7
joepcrepairs2
16
Drives: e92
post a copy of your .trc
      04-04-2014, 05:43 PM   #8
Wycy
Attached
      04-04-2014, 05:50 PM   #9
deeLow
DOPE
deeLow's Avatar
148
Drives: F80
Interesting. E90 or 92? Lci or pre?
      04-04-2014, 07:08 PM   #10
joepcrepairs2
16
Drives: e92
nicht_aktiv this:
WL_POL_3R
      04-04-2014, 08:48 PM   #11
Wycy
It's an E90 LCI (2011 328xi).
Actually, WL_POL_3R was the first thing I tried to set nicht_aktiv because I confused corner lights and sidemarkers. According to the spreadsheets, WL_POL_3R is for the cornering lights, but in my case setting it nicht_aktiv turned off my angels during welcome lights, which was weird, so I turned it back to soft_einschalten.
Really not sure why it's behaving this way.
      04-05-2014, 02:34 AM   #12
deeLow
DOPE
deeLow's Avatar
148
Drives: F80
I've read somewhere that on the LCI cars the side markers can't be shut off for the WL.
      04-05-2014, 09:09 AM   #13
Wycy
Ahh really? That's a bummer.
      04-05-2014, 11:12 PM   #14
Wycy
Just discovered something interesting: WL_SL_2_3R as nicht_aktiv acfually ended up turning off my tail lights instead of the sidemarkers. I've now reenabled the SL_2.
      04-07-2014, 05:10 PM   #15
Wycy
Since the sidemarker parameter on this car is SIDEMARKER_US_MIT_FRA_V, I wonder if perhaps the right WL parameter is WL_FRA_V, which is currently set to soft_einschalten. I haven't found any other descriptions of what WL_FRA_V could be, so maybe this is it. I'll give this a try soon and update if successful.
      04-07-2014, 05:27 PM   #16
deeLow
DOPE
deeLow's Avatar
148
Drives: F80
Are you talking about the 3 LED lights on side of housing?
      04-07-2014, 06:32 PM   #17
Wycy
Hm, to be honest, I'm not sure what the specific light situation is in terms of # of bulbs and bulb vs LED, etc. Basically I'm looking to turn off this yellow light:
      04-08-2014, 03:00 AM   #18
deeLow
DOPE
deeLow's Avatar
148
Drives: F80
Got it. Did you try the fra_v option you mentioned earlier?
      04-08-2014, 07:12 PM   #19
Wycy
Just did and can confirm, setting WL_FRA_V to nicht_aktiv in NFRM had the desired effect of turning off sidemarkers during welcome lights Pic:
Interestingly, the sidemarkers still flash when I unlock the car, but they don't illuminate after flashing. It ultimately leaves just the angel eyes on.
      04-08-2014, 09:39 PM   #20
WaLLy350GT
Psshh!
WaLLy350GT's Avatar
Drives: E90 335i
Gonna have to test in mine sometime. Thanks for the info. I'll update as soon as I change it.
