2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Some wheel information /w photos. Forgestar SDC's and SemiDeeps
      04-02-2014, 08:22 PM   #1
Cripple
Cripple's Avatar
102
Drives: 12' 335is
I am in the process of developing a wheel with ADV1 for this car but needed to physically see what I was dealing with (actually mounted) on stock suspension. I took a set of wheel I had kicking around and just did a test fit. Here is a quick glance at some aggressive offsets.
19x10 ET27
19x8.5 ET35
So, I am thinking 19x10 ET36-37 should be perfect!
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com
Current: 2015 Cayman S on HRE P101
      04-03-2014, 01:52 PM   #2
M.barnes
41
Drives: 123d
Et36 sounds aggressive for the 2 but then the pictures would say otherwise!
      04-03-2014, 01:55 PM   #3
M.barnes
41
Drives: 123d
Just realised why.
You can't take a 10" wide wheel that's 5cm too wide, then put an 8.5" wheel on at nearly the right offset then assume the width of one and the offset of another will work.
What you are proposing is 1.5" wider, therefore 3cm wider (at least) so 1.5cm extra either edge and only 3mm less offset so the wheel will still stick out.
You'd need 10" x et50 approx I'd say
      04-03-2014, 01:56 PM   #4
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Originally Posted by M.barnes View Post
Just realised why.
I'm worried about strut side on a 10"
2addicts
