Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      03-28-2014, 02:50 PM   #1
E90Fleet
South Africa
1311
Drives: BMW
F80/F82 Lithium Ion starter battery
Not much talk around about the F80 and F82 Lithium Ion battery used instead of the now regular AGM battery.
Interestingly the battery has built in electronic controls, so things like the Intelligent Battery Sensor (IBS) is a thing of the past.
The battery plugs int the cars LIN BUS so the systems can monitor it.
50% weight saving over AGM
Thoughts ?
EDIT:
One major drawback is one cannot use regular car battery chargers, since they charge above 14V, which will damage the Li-Ion battery.
Hope dealer remember this when going in for a service and they hook up a charger for the diagnostics
BMW if you are reading, I need a job, Please.
FSociety3811.50
      03-28-2014, 03:08 PM   #2
JustChris
JustChris's Avatar
No_Country
17483
Drives: Tesla MYRWD
Impressive. Like you say, with all the focus rightly on weight saving you think it would attract more press.
My car made front page of Bimmerpost
      03-28-2014, 03:10 PM   #3
signes
signes's Avatar
199
Drives: 991 GT3 RS
Weight saving is nice, curious about longevity and cost. E9x M3 batteries are already about $500 with the BS initializing fee tacked on. The new tech sounds very expensive, we'll see. Last thing I would want is a battery that only lasts 2 years and costs $800 to replace. Hopefully both of those points are exaggerations, and who knows, maybe will last longer.
GT3 RS | Desperately seeking the next great M car...
      03-28-2014, 03:11 PM   #4
hacxyzzy
hacxyzzy's Avatar
50
Drives: e46 M3, SO/SB M4 MT
Interesting. How will it behave in cold weather though?
      03-28-2014, 03:23 PM   #5
E90Fleet
South Africa
1311
Drives: BMW
BMW says it has improved cold weather performance over AGM battery down till 0C
      03-28-2014, 03:28 PM   #6
E90Fleet
South Africa
1311
Drives: BMW
Life is supposed to be better than AGM.
Sure cost will be high untill main stream models get it aswell
      03-28-2014, 04:56 PM   #7
swamp2
swamp2's Avatar
609
Drives: E92 M3
Interesting, relatively mundane things can really help the battle of the bulge...
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      03-28-2014, 05:03 PM   #8
E90Fleet
South Africa
1311
Drives: BMW
Interestingly BMW speak more about it being a superior power platform for the ever increasing electricity demands of modern cars than its small weight savings.
      03-28-2014, 05:21 PM   #9
consolidated
consolidated's Avatar
205
Drives: F80 M3
$1700 option on a Porsche (but much smaller). I like it, thanks BMW.
Carl L195.50
      03-28-2014, 05:28 PM   #10
parky1215
parky1215's Avatar
561
Drives: F90 M5C | G06 X6 M60i
My car battery charger box says 12v with 2, 10, and 50 amp setting. I guess this one should be ok charging new battery on m3?
      03-29-2014, 01:54 PM   #11
E90Fleet
South Africa
1311
Drives: BMW
Sounds like a standard lead acid battery charger that wont work.
Only Li-Ion ones I know are industrial spec machines with specific software for them.
BMW have not confirmed yet which countries would get the Li-ion batteries.
It may be all or only just some.
So till deliveries start one cannot know if one needs a new charger or not.
      03-29-2014, 02:07 PM   #12
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
24975
Drives: '22 Chalk Gray Porsche C2S
Nice!
      03-29-2014, 03:22 PM   #13
Jockey
Jockey's Avatar
3445
Drives: 992 C4S
Interesting. My BMW battery tender I guess will now be worthless
      03-29-2014, 03:25 PM   #14
Pavit
Pavit's Avatar
Mauritius
50
Drives: Bimmer Beauty
The most important part of Lithium Ion batteries is the BMS (Battery Management system) that monitors each cell's state and give's accurate reports of the storage unit's actual capacity!
Compared to Lead batteries which have a nice curve depending on their charge status it is not same for Lithium Ion ones, also a curve used by most current lead charge controllers to replenish a flat battery!
We use Li Ion storage a lot here de to their higher life span (cycles) and efficiency (much much better than lead alternatives), yes you can use a normal lead battery charge controller as long as you are respecting the max cell voltage but then you start saturating the Lithium Ion battery and cause it to wear out fast/fail once it's full and keep pumping in current!
Good read on the subject:
http://batteryuniversity.com/learn/a..._ion_batteries
Though back to initial topic, good to see the use of Li-Ion battery in here, less weight, better lifetime, no real issues of wear when exposed to the same temperatures inside the engine bay as with Lead batteries.
      03-29-2014, 03:52 PM   #15
ZGM3
47
Drives: bmw
any issues with jump starting the battery/car?
      03-29-2014, 05:57 PM   #16
karussell
353
Drives: 4 wheels
i think the standard charger will work. again porsche went through this and there is no special charger for the Lithium batteries. i have had it in my gt3 for past 4 years. take it out in winter months in germany and put standard one in. it doesn't like temps below 40f. hellova lot lighter than regular battery but have no idea its in the car performance wise.
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
      03-29-2014, 06:59 PM   #17
M4TW
///M Uber Alles
M4TW's Avatar
332
Drives: '15 MW M4
I hope they use the regular batteries for Canadian spec'ed cars. I don't mind saving weight but a slightly lighter car that doesn't start when you need it to is worse than a few extra pounds.
die Welt ist meine Auster
2015 M4, MW, Black Full Merino, DCT, CCB, Adaptive M Suspension, Premium, Executive. Technology, ConnectedDrive, CF Trim, Convenience Telephony, European Delivery
      03-29-2014, 08:21 PM   #18
swamp2
swamp2's Avatar
609
Drives: E92 M3
Many (most?) BMWs have their batteries in the trunk anyway and I'm sure the new M3 and M4 do.
      03-30-2014, 04:37 AM   #19
E90Fleet
South Africa
1311
Drives: BMW
BMW are specifically warning against standard chargers that charge at over 14V.
Dealers have to have their workshop chargers software upgraded to include Li-ion settings. The equipment currently charges AGM batteries at 14.8V. Most amateur chargers charge between 14V and 15V.
I see CTEK has a lithium ion specific charger in both USA and European forms that charges at 13.8V.
      03-31-2014, 03:11 AM   #20
stressdoc
Moderator
stressdoc's Avatar
Dominica
617
Drives: BMW i8; Toy 4runner TRD pro
A lot of us got Braille Lithium batteries for our E90s to reduce weight. No real problems with the bigger ones for DD use.
And damn, BMW has still not hired E90fleet?!
      03-31-2014, 04:31 AM   #21
E90Fleet
South Africa
1311
Drives: BMW
No, wrong color so cant even get a interview
      03-31-2014, 07:50 AM   #22
ersin
ersin's Avatar
126
Drives: 17 YMB F80 M3
Li ion is the future. Soon the majority of cars will be using these kinds of batteries. They are supposed to last longer and are lighter than common lead acid batteries. It's a good thing that BMW is starting to use these. I'd have liked to have seen them in the E90 M3's. I guess they weren't quite ready until now.
Cheers.
2017 F80 YMB.
f80post
