03-27-2014, 05:20 PM | #1 |
Rep 18
S55 vs N54 dyno characteristic
I think the dyno graph shape for the S55 and N54 is very similar. I am not talking about numbers but the characteristic of the HP and torque lines.
Link to N54 stock dyno: http://www.1addicts.com/forums/showthread.php?t=432677 Link to S55 manufacture "dyno": http://f80.bimmerpost.com/forums/sho...d.php?t=893935 Both torque curves have the following characteristics: start with sharp rise, flat middle, and drops off at the end. HP curve: start HP line slope is higher compared to middle, flat end. Does this mean the S55 will feel similar to N54/N55? |
03-27-2014, 05:39 PM | #2 |
561
Rep 1,980
It will feel different @ top end.
N54's HP falls down after 5800 RPM while S55 will produce max HP from 5500 to 7300 RPM. S55 will have best of both Turbo (low RPM torque) and NA engine (top end HP) according to spec sheet. Hopefully that will be how the car actually drives. |
03-27-2014, 11:16 PM | #3 |
driver mod in progress
225
Rep 1,858
Drives: with both feet
Regarding the characteristics, you're right when discussing the stock torque and power curves, but as soon as the coding is cracked and somebody optimizes a tune for E85, look out! My dyno from earlier this year with a blend of E85 and 91 octane, netting an E60 blend, is shown below.
Note that this is with my daily driven fuel blend and tune as better numbers are achievable when cranking up the boost and more timing advance. I hope the S55 torque curve is like the N54 but even better, as I love mine. It's a tire shredder, but man is it fun to drive. Link to Video of Dyno Run shown above
03-28-2014, 12:47 AM | #4 | |
66
Rep 1,131
03-28-2014, 05:26 AM | #5 |
21115
Rep 20,741
Drives: 2021 911 turbo
You cannot really compare the two power curve images you provided. One is a marketing "cartoon" while the other is a chassis dyno chart. Both are imprecise in their own way. To do an apple to apples comparison, we should use both the marketing cartoons. I used the 1M power curve here. IMO, the S55 will feel much stronger on the top end due to the broader power plateau and higher overall output with much more useable power.
Since the S55 is a FI engine, it will also be closer to the N54 in terms of feel than to the S65. I am not yet convinced this is a good thing. I guess I will find out when I pick-up my M4 this coming July. |
03-28-2014, 10:37 AM | #6 |
107
Rep 1,997
Apparently the new N55s had a slight tweak to their turbo (or the exhaust part of it) and are seeing a more flat curve at the top rather than the insane drop off everyone hates.
BMS is testing out the electronic wastegate version of the newer ones and has a 2014 435 putting down over 400whp and says there is still room for growth. The curve looks nice and pretty near the top. Color me and my '12 335 jealous. Let's hope BMW was on to something and the true power curve is exactly what they're painting in their cartoon. The newest development of the N55 makes me optimistic. |
03-28-2014, 10:44 AM | #7 | |
592
Rep 5,396
the m3 is a different ball game as its twin turbos vs single, different internals, different cooling system, different turbo placement etc....
03-28-2014, 10:48 AM | #8 | |
107
Rep 1,997
//M cars should be loads of fun. |
03-28-2014, 10:52 AM | #9 | |
592
Rep 5,396
I am not worried at all about power in the m3. I think the car will absolutely rip, and there will be more power on the table once the tuners get the cars and get cracking. One thing that would be nice is if the cooling system is as good as I hope it is. The n54/55 cars basically need IC upgrades in stock form, even the 1M which had a more robust system (mainly oil coolers and secondary radiator).
03-28-2014, 11:56 AM | #10 |
609
Rep 10,407
Given that what we feel (at least if we only consider the butt-o-meter), moment by moment, instantaneous acceleration, is governed by the shape of the torque curve, I suspect they will feel quite similar. They will certainly feel more similar than the new M3 will feel to the current one.
Sure the car will be substantially faster, will make better sounds (than the N54) and this will also mask some of the overall similarity. It is hard for us to be fully unbiased and separate each of our senses (visual, inner ear (acceleration), ear (acoustics), vibration, etc.). The overall shift to the right of the torque curve will also mask some of the similarity. Some of the short shifting we've seen in the M3/M4 videos also speaks to engine character and feel and this bolsters my point of view.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
03-28-2014, 06:39 PM | #12 |
225
Rep 1,858
The info requested about the electronic waste gate tuning improvements is found on that other forum. Good stuff by Terry as usual.
http://www.n54tech.com/forums/showthread.php?t=23709 As for the S55's sound, the OEM exhaust tone is pretty bland if you ask me, but then again so is the N54's. By the time you remove the cats from the downpipes to reduce turbo lag and upgrade the mufflers it will sound really good; it won't be as good as the V8 S65, but few sounds are. I'm counting on the S55 to come from the factory with much improved cooling and be ready to withstand track duty out of the box. If it didn't, I wouldn't even consider making the switch. To maximize the N54's potential and fully enjoy it on a track, just take a look at the mods in my sig. I had a major focus on cooling (i.e. - dual oil coolers, larger intercooler, water wetter additive with only distilled water in the radiator, m3 bumper for better airflow, etc...). Even upgrades to the fuel system help as E85 burns cooler than traditional fuel and much cooler than race gas - the NGK 5992 plugs with tighter gaps are needed for such high blends of the corn fuel.
03-28-2014, 07:44 PM | #13 |
40
Rep 493
Drives: 2013 BMW 335is
03-28-2014, 08:25 PM | #14 |
17
Rep 239
03-28-2014, 08:51 PM | #15 |
352
Rep 2,176
It's not a scam , it actually increases the waters boiling point and prevents micro bubbles from forming in the radiator . Those bubbles cause reduced heat transfer from the motor to the radiator . I see an avg decrease in water temps on track of 15 degrees using it with water vs antifreeze /water mix . Not sure where you pulled its a scam from but you're dead wrong .
03-28-2014, 09:09 PM | #16 |
40
Rep 493
Agreed. I run about 20 degrees cooling in my track car with Water Wetter.
03-29-2014, 07:16 AM | #17 |
254
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
Haha reduce the boiling point.
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
03-29-2014, 02:18 PM | #19 |
40
Rep 493
Once you let your car get to 305F, the additive is pretty much a moot point.
You have a bigger problem on your hand. I know first hand... http://my350z.com/forum/maintenance-...eavy-pics.html |
03-29-2014, 10:00 PM | #20 | |
17
Rep 239
The point is
The interesting part of the graph is below 250F... |
04-04-2014, 09:14 AM | #21 |
Save the Manuals
1714
Rep 2,937
OCD kicking in again
regarding wording here: It doesn't reduce boiling point. It decreases the residual heat in the block, by more efficient heat transfer.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
04-04-2014, 09:51 AM | #22 |
21115
Rep 20,741
^ This
It has not much to do with boiling point, but rather with specific heat capacity. Water is a very efficient medium to convey heat energy (ie, you need a good amount of energy to raise a given amount of water by 1 degree). Adding additivies (such as glycol) is great to prevent freezing and corrosion is the coolling system, but it reduces the specific heat capacity of the fluid in the cooling system. This is very well portrayed in the graph in the previous post where it shows cooling time depending on the fluid mix. |
Tags |
dyno, n54, s55 |
