11-16-2007, 07:24 PM | #1 |
Rep 46
mtec HID installation
If any of you have done the mtec HID installation, where did you mount the ballast? Inside the light housing? Or did you mount it outside and drill and use a grommet to fill the hole?
Just switched to Sylvania bulbs to see if I can hold back on the HID kit... |
11-16-2007, 09:49 PM | #2 |
61
Rep 1,210
You should be able to fit it inside the headlight cover, it'll probably be a better bet to fit it in there then drill a hole and use a rubber gasket.
11-16-2007, 10:55 PM | #4 |
61
Rep 1,210
There shouldn't be, you should be able to plug the stock H7 connector probably into a adapter cable H7-->9006 then into the ballast, ballast goes to the bulb and you should be able to tuck everything inside, close the cover and snap on the metal bar thing.
11-16-2007, 11:56 PM | #5 |
Rep 46
Thanks guys. It looks like there are a couple of kits that allow for a direct connect to the ballast without a 9006 adapter. Now I just have to be confident that they will not throw a bulb error.
11-21-2007, 02:41 PM | #9 |
20
Rep 259
I removed my front bumper today..
I'm in the process of installing a new Aero front bumper and while it's off I thought I would show you how I put in my MTEC hids... I actually used heavy duty velcro to attach the unit to the side in front of the wheel well. They have been there for over a year and have not moved... Not much water gets in that area, but I mounted them up little bit just it case. The kit came with a gromet to go around the headlight wire.. I did have to drill a hole in the cover... but it can be easily plugged if I remove the hids...
11-26-2007, 06:13 AM | #11 |
Rep 35
can I install mtec without removing front bumper ?
Sterling grey ,108 starspoke, alarm,KW v3 suspension,clear lights,cd/mp3, ipod 20GB, hardtop,manual,wind deflector, aerodynamic package, silver trim,Michelin pilot sport tyres, cruise control etc ...http://www.freewebs.com/knb921/
11-26-2007, 06:34 AM | #12 |
20
Rep 259
No errors... more
I get no errors at all... I installed mine by pulling back the rubber wheel well... it's very flexible. You just have to remove the 4 plastic pins in the expanding rivets connecting the wheelwell to the front bumper and a couple screws over the wheel. You have to remove the wheel.. The whole job took about 30 minutes... Hope this helps..
11-26-2007, 10:44 AM | #13 |
Rep 35
where did you install ballast?
11-26-2007, 11:15 AM | #14 |
Rep 35
from where did you get power for the ballast ?
11-26-2007, 12:18 PM | #15 |
61
Rep 1,210
You dont even need to remove your fender lining, removing the upper panel in your wheel well should be plenty of access. The ballast is powered by your stock halogen bulb wiring and you can mount the ballast anywhere that is stable and dry. Most people either double sided tape or zip tie it to a support brace.
11-26-2007, 12:25 PM | #16 |
20
Rep 259
That is te ballast
That is the ballast mounted in my pictures above. It is very easy.. you simply remove the cover to the back of your light, then pull the headlight wire back. Plug that wire to the ballast. Mount the ballast. New Hid bulbs come with the kit. You have to drill a hole in the cover and run the new bulb wire through it (there is a gromet that seals the hole). Plug that wire into the ballast and your done... no errors.. Just make sure you get the real MTEC hids... it looks like there are some fakes out there. Also, as I remember now, I did the install through the access port in front of the wheel... I had to fold back the wheelwell when I put in the fog lights... Chuck
11-26-2007, 02:26 PM | #17 |
Member
Rep 76
Drives: 2003 Z4 2.5 Sport
Great advice & pics! Just purchased the mtec kit and was unsure about the install. Now I think I'm ready!
BMW rear spoiler - de-badged - MTEC HIDs (DEFECTIVE) - XENESIS high beams & fogs - shadowline front grill - 20% tint - keyhole plugs - Roadster Solutions acrylic wind deflector - LeatherZ center console & door arm rests - Parrot 3100 bluetooth - USA SPEC IPod integration - Xenon interior lighting |
11-27-2007, 12:10 PM | #19 |
Rep 35
from where did you get power?
11-27-2007, 12:15 PM | #20 |
20
Rep 259
Power
It gets it's power from the original light sourse (the wire that now connects to your bulb).. no other power is needed... Chuck
11-27-2007, 01:58 PM | #22 |
Member
Rep 76
purchased on EBay from "mtecpower". The delivery charges were minimal and the devlvery time was fast.
