Failure warning rear light on! Need help.
03-21-2014, 12:16 PM | #1 |
Rep 77
Hello.
If someone know what to do with this issue please tell me what to do, I'm tired of seeing this warning light and when I need to used the right turn signal, it start to blink like crazy. I did went and disconnect the (right turn lights build set) and didn't see anything wrong it work good for a couple of days and the it came back the issue please help. |
03-21-2014, 12:25 PM | #2 |
89
Rep 3,732
Drives: BMW S1000XR
I have the same error It occurred when I disconnected my stock angel eyes to install my umnitza V2. I am not too worried about it at the moment.
Try: 1) view check control 2) press the button in on turn signal stock and hold 4 seconds. A code will appear. Post it.
BMWCCA member Last edited by ken1137; 03-21-2014 at 02:47 PM.. Reason: clarification |
03-21-2014, 02:46 PM | #3 |
89
Rep 3,732
Drives: BMW S1000XR
send me your cc - error code. just checked mine again and they are:
cc-130 > FRM - Parking light front left cc-380 > FRM -turning light right failed These could be due to my light mods, but there is nothing wrong with either light indicated in the error code They come back each time I clear them. BTW...if you turn signal is blinking like crazy you need to replace that light, and/or check the wiring.
BMWCCA member Last edited by ken1137; 03-21-2014 at 02:52 PM.. |
03-21-2014, 04:33 PM | #4 |
453
Rep 2,973
What mod's did you do.
The light circuit is current and connection sensing. If you swapped with LEDs this could happen. Not drawing enough current.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
03-21-2014, 04:46 PM | #5 | |
Rep 77
03-21-2014, 04:46 PM | #6 | |
Rep 77
I will check and let you know. |
03-22-2014, 10:48 AM | #7 |
Rep 13
I am getting that same error code that an exterior light is malfunctioning. It started two days ago upon start up. Now I get it will driving. Stays on for a minute or so then goes away. I have looked at all of lights, and all seem to be working. I too would like to know what to do -- other than bring it back to the dealer at $120 an hour.
Thanks |
03-22-2014, 11:38 AM | #8 |
EXPAT
65
Rep 889
Had the same last month, right rear brake light. Turns out that there are two brake light bulbs per side--so very hard to "see" that there's a problem by having someone stand on the brakes.
I ended up going to the auto parts store and buying new light bulbs (signals, reverse, brakes, parking, etc) for the entire car. Excluding headlights (which I ordered from Amazon), I think its cost me about 20 Euros. If it's just a bulb, should be an easy job -- just follow your owners manual and be gentle with plastic bits that the bulbs go in to. |
