Alpina TCU code 511b
03-20-2014, 11:05 AM | #1 |
30
Rep 452
Hey guys I've tried to search what this code means but I haven't found anything on it. TCU code 511b. The tranny shifts great, I have 60k miles on it, fbo with giac. I changed the ATF fluid at 50k to redline. I've just ignored the code and kept driving the car. Any thoughts?
GIAC, Alpina TCU Flash, Ohlins, Brembo, Eisenmann, Quaife, Evolution Racewerks, Wagner Tuning, AFE, M3 suspension bits
03-20-2014, 12:07 PM | #2 |
The Wolf
250
Rep 988
Drives: stuff
it's a known fault code when flashing alpina, there is no fix and it was never addressed by bmw... not an issue though
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
03-20-2014, 01:15 PM | #3 | |
30
Rep 452
03-20-2014, 02:06 PM | #4 |
BimmerPost Supporting Vendor
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
ALLDATA has a BMW SB regarding this error. It's an incomplete coding error that BMW indicated they would fix in the next service release... Never happened. Don't worry about it. It's not an issue..
03-20-2014, 02:12 PM | #5 | |
30
Rep 452
08-20-2014, 01:14 AM | #7 |
34
Rep 1,093
08-20-2014, 01:15 AM | #8 |
1334
Rep 1,701
According to the SB the 511b doesn't cause a service light. The code is specifically "code missing". I have SPDaten 53.0 now so I'll look for updates. But I doubt if BMW or Alpina did anything regarding this as it doesn't cause any issues.
08-20-2014, 01:22 AM | #9 |
530
Rep 2,084
I used INPA to scan for codes. I also have a 2D2E code, but I've had this code before without and SES light, so I assumed the 511B was giving me the light. If its not causing the light and it doesn't indicate there's a problem then I don't really care about it.
08-20-2014, 10:51 AM | #10 |
The Wolf
250
Rep 988
Drives: stuff
"2D2E:
2D2E Angle of throttle valve - intake pipe underpressure, correlation Error will cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption "
08-20-2014, 09:03 PM | #11 |
530
Rep 2,084
Well the SES light did not come on today, but I scanned with INPA and 2D2E was there. So why is there no SES light this time?
2013 135is DCT Carbon Black Metallic |
08-20-2014, 11:33 PM | #12 |
34
Rep 1,093
If the code is stored but not active it will show up on scan but no SES light. Does it say H2D2E rather than P2D2E. Not sure how inpa displays history codes as I use a different scanner. But this is likely why you don't have a SES.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
08-21-2014, 12:02 AM | #13 | |
530
Rep 2,084
View post on imgur.com
08-21-2014, 02:22 AM | #14 | |
34
Rep 1,093
07-10-2020, 10:17 AM | #15 | |
Rep 2
Drives: 2008 BMW 335i
511B Error Code
07-10-2020, 07:33 PM | #16 | |
875
Rep 5,457
You just need to code it with ncsexpert as in this post with the file provided and it will fix it https://bmw.***********.com/threads/...e-8#post-11373 It also caused an issue with XHP flashing previously alpina coded cars originally but XHP fixed it to do the coding if it was missing. Forum killed the link, asterisks are s p o o l s t r e e t Here is how to do it - Copy the file attached in your C:\NCSEXPER\PFL folder - Start NCS - Load Profile Expertmode FSW PSW Manipulate ohne MAN - Hit F2 (Chassis), Select E89 - Hit F1 VIN/ZCS/FA - Hit F3 ZCS/FA f. ECU, select CAS - Hit F6 (Back) - Hit F4 (Process ECU), select EGS - Hit F3 (Execute Job) - Done Please make sure that the text matches the functions on your F-keys in NCS! if the text appears at another F-Key, use this one!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey Last edited by roadkillrob; 07-10-2020 at 07:38 PM.. |
07-17-2020, 02:46 PM | #17 | |
Rep 2
"WARNING: At this point, it is very easy to do something that could make your entire car explode. Always remember that coding is serious business. The default job is SG_CODIEREN which will write to the selected module using the values in FSW_PSW.MAN, which is presently empty. Be extremely careful any time you use NCS Expert, but especially at this stage in coding. I bought the car with the JB4 w/ MHD BEF and the Alpina flash already installed. So I don't have the connector cable or any experience working in the software. I think I might try to find a local tuning shop to do it or just deal with the error on my dash. I appreciate the help |
07-18-2020, 08:04 AM | #18 |
875
Rep 5,457
What error do you have on your dash, a 511b is a shadow code, it won't set any dash light.
If you are thinking of paying someone to fix the 511b, for probably not much more money you could just buy XHP and flash your trans, it is better than the Alpina flash and most of the cars flashed with the Alpina flash had the 511b error that would cause issues flashing XHP, so XHP fixed the issue and they add the coding when they flash the car, so you get it fixed and a better trans flash with more options. You will need a cable or dongle but it isn't like NcsExpert, it is an app that you just pick setting and write it to the car.
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
07-24-2020, 07:19 PM | #19 |
Rep 204
Drives: 2008 M3 E92, 2007 335Xi E90
I flashed the xHP and that code was still there afterwards
