XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 Photos / Videos / Media
      03-19-2014, 11:16 AM   #1
Activ3
clutch-kicker
Drives: e46 328i
Lowered my Valencia Orange M-sport!
Just installed a set of BC coilovers on my X1! Purchased and installed at Precision Sport Industries (www.precision-sport.com), they are the prototype BC's for this car, and so far fit great. The wheels are Rays 2x8 19" staggered.
Upgrade+129.50
      03-19-2014, 11:40 AM   #2
Twix
Twix's Avatar
652
Drives: 2011 e91
Looks good. Good your camber in the rear?
      03-19-2014, 02:15 PM   #3
Black Flagged
Black Flagged's Avatar
470
Drives: M2C
Looking gangsta' player...
Appreciate 2
      03-19-2014, 02:47 PM   #4
Redsoxx1918
14
Drives:
Pimpin'
      03-19-2014, 05:04 PM   #5
punchyninja
Drives: BMW X1 x28i 2014
looks nice!
      03-19-2014, 06:19 PM   #6
Bamsterman68
61
Drives: 2014 X1 sDrive28i ///M-Sport
do you have any pics of the actual coilovers?
      03-20-2014, 12:45 PM   #7
Gort
Klaatu Barada Nikto
Gort's Avatar
No_Country
28
Drives: 2017 X3-35i
Have you noticed any improvement in handling?
      03-20-2014, 12:51 PM   #8
Activ3
clutch-kicker
Drives: e46 328i
It's at the alignment shop now. I asked for -1.5 rear and -2.0 up front. I'll see what they say. The camber wasn't too bad, but it was definitely more negative than it should be.
Originally Posted by Redsoxx1918 View Post
Pimpin'
Originally Posted by punchyninja View Post
looks nice!
Thanks guys!
I did take a few during install, once I get them off of my camera I'll definitely post a few shots.
It's getting aligned today, once it's done I'll let you know. I'm sure that since I can now properly align it with the front camber plates, that alone will make a difference in handling. I had BC's on my R56 cooper, and currently have some on my e36 racecar, and they've worked great so I can't imagine these to be any different.
      03-20-2014, 02:11 PM   #9
EdgeCrusher
44
Drives: M3
Looks Good ! I am thinking about the BC coil-overs as well... not sure if I am going to stay with my X1 yet....
      03-20-2014, 04:31 PM   #10
Activ3
clutch-kicker
Drives: e46 328i
Just had the car aligned. Max positive camber that could be achieved in the rear was -2.22*. Adjustable bushings will be needed to go any more positive than that.
      03-20-2014, 07:12 PM   #11
GTony
Australia
27
Drives: 2015 X3 F25 XDrive 28i M Sport
Looks fantastic. I have similar wheels but chromed 7 double spoked. What size, width and offset are they.
      03-20-2014, 08:59 PM   #12
ddas
ddas's Avatar
210
Drives: 2018 Daytona Violet M3
Tight.
      03-20-2014, 10:36 PM   #13
squishy
Zimbabwe
153
Drives: 2014 Ford Mustang GT
Looks great!!
      03-21-2014, 01:26 PM   #14
Activ3
clutch-kicker
Drives: e46 328i
Thanks! 19x8.5 et24 front 19x9.5 et36 rear. I'm likely going to space the front and rear another 12mm or so.
Originally Posted by ddas View Post
Tight.
Originally Posted by squishy View Post
Looks great!!
Thank you!
      03-23-2014, 09:01 PM   #15
wantm135i
wantm135i's Avatar
43
Drives: x1 35i m sport
looks real sharp, dont go wider than 12mm on the spacers or it will rub. iam running 15mm all around had to remove about 1/4 inch on the inside edge lip and iam running the 9" wide rims up front like the back.
      03-24-2014, 03:40 PM   #16
Activ3
clutch-kicker
Drives: e46 328i
Thanks!
I ended up swapping to 225/40/19 front and 255/35/19 rear, with a 20mm spacer up front and a 12mm spacer in the rear and it does rub the rear sometimes.
I'm tracking the car this weekend and will be swapping on 18x9 et27 285/35/18 up front and 18x9.5 et45 295/35/18 rear so we'll see how it does with the stickier tires and coilovers!
      03-30-2014, 09:52 PM   #17
wantm135i
wantm135i's Avatar
43
dude sounds allsome let us know how it goes.
      03-31-2014, 12:24 PM   #18
Activ3
clutch-kicker
Drives: e46 328i
The car handled pretty good. It pushed a little on entry, but I was able to drive around it by kind of flicking it in. I have 7k front springs, and 11k rear. I softened up the front dampers and stiffened the rears, and ended up with 30psi front and 37psi rear hot for tire pressures. Overall I can't complain, it's not a racecar haha.
      03-31-2014, 06:43 PM   #19
Black Flagged
470
Drives: M2C
That's kick ass player...
      04-03-2014, 02:02 PM   #20
paradoxical3
1008
Drives: BMW
Awesome, nice to see someone else tracking the X1. Did you seriously fit 285 rubber up front and 295 in the back? Holy crap.
The amazing thing to me is that the people you were chasing didn't seem to leave you that much on the corners, just on the straights where you are clearly down on power. If you had another 50hp I bet you would have kept up just fine. Could just be that you're a better driver than them too.
      04-03-2014, 03:59 PM   #21
jm6001
Drives: X1 35i M
Do you have the JB4? I noticed your one gauge fluctuating, assuming its your boost level?
      04-04-2014, 08:01 AM   #22
Activ3
clutch-kicker
Drives: e46 328i
Thanks!
Thanks man. I was able to fit the 285s up front on a 9" wheel et17, and the rear 295s on a 9.5" wheel et45. I had -2.8* F and -2.3* R camber though, 0 toe. The car really did handle pretty good for what it is, I was trying pretty hard to hang with the old silver Porsche in front of me, but he kept inching away down the straights!
I do have a JB4. I should have mentioned that in map 1 the car would maintain higher boost levels for the entire 25 minute session, but in map 2 it would shut down to OEM power after about 15 minutes (Oil temp was getting too hot). I'm on 93 octance and it was roughly 65-80 degrees F at the track that weekend.
Search this Thread:
Advanced Search
xbimmers
