Boost Oscilation/boost leak
03-10-2014, 09:14 PM | #1 |
77
Rep 339
I m having boost oscillations after installing the COBB stage 1 aggressive tune. I am wondering if the cause can be a boost leak? I am hearing whistling sound under heavy throttle, could that be a boost leak sound I am hearing? I am not getting any codes thrown so if it is a boost leak it has to be minor. How do I go about detecting if it is a boost leak?
I have my log attached. If anyone could tell me for sure if it isn't a boost leak or if it is a possible boost leak and how to go about diagnosing it and fixing it that would be great. http://www.datazap.me/u/tennispr0/co...pulls-3rd-gear |
03-10-2014, 10:07 PM | #2 |
34
Rep 1,093
I would expect to see a sharper drop for a boost leak. It looks more like your wastegates where cycling while you were over requested boost. I would try one of two things. Run more boost eariler in the rev band to see if it has them same symptoms. Or if you have shop air I would pull off your intercooler inlet pipe and pressure test to 20psi. This is assuming you did the normal boost leak checks of tightening connections checking for cracks and oil residue.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
03-10-2014, 10:29 PM | #3 |
77
Rep 339
I do not know how to do the normal boost leak check. Do I just check and make sure clamps are tight that are connected to the intercooler basically?
Can anyone else chime in on this if it seems like a boost leak or not and if so, how can I check where it is leaking. |
03-11-2014, 12:57 AM | #4 |
38
Rep 634
I see no signs of a boost leak in that log. WGDC is well within expected range and shows no evidence of having to overcome a leak. The boost oscillations/over boost appears to be your only problem.
03-11-2014, 08:17 AM | #5 |
77
Rep 339
Cool thanks a lot for the reply. I am hearing a whistling sound under heavy throttle, could that be a boost leak? I mean if it was a small boost leak, would it even be possible to hear it like that while driving? If not, then I will dismiss the possibility of the boost leak. Thanks in advance.
03-11-2014, 08:49 AM | #6 |
421
Rep 1,643
There's a thread on here for how to replace your vacuum lines. You may want to check them all for leaks.
2007 E92 335i MT
03-11-2014, 08:50 AM | #7 | |
34
Rep 288
You are averboosting which causes throttle closures which makes waste gate open to release excessive pressure. You don't have a boost leak.
Cobb / DCI / VRSF Downpipes / VRSF 7" Intercooler / Walbro LPFP / E85
03-11-2014, 08:53 AM | #8 | |
77
Rep 339
I know to fix this I should get a protune, but is there any other way? I have the COBB stage 1 aggressive tune by the way. Are others with this tune having the same problem? |
03-11-2014, 08:58 AM | #9 | |
34
Rep 288
Base is the trickiest one to dial in, not something I would recommend you do yourself if you have no idea what to look for.
03-11-2014, 09:03 AM | #10 | |
77
Rep 339
