335i dual mass flywheel
03-08-2014, 09:40 AM | #1 |
Rep 34
Does anyone one know the part number for the 2010 335i e92 flywheel I've been searching but can't find anything I found one that says DMF134 but not sure if that's it and it's made by luk.
03-08-2014, 10:04 AM | #2 |
58
Rep 665
Did you check realoem? Look like the part number is 21207640733. MSRP is $1200 although you can save several hundred by ordering it online from places like getbmwparts.com (BMW of Silver Spring, formerly Tischer BMW)
http://www.realoem.com/bmw/showparts...87&hg=11&fg=20
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
03-08-2014, 10:11 AM | #3 |
Rep 34
Yea but I've been looking and most say it's only from 07-09 and mine is a 2010 and 2011 and up are n55 so does that menu 2010 only has a special one for that year?
03-08-2014, 01:22 PM | #4 |
59
Rep 886
try luk it's much cheaper!!!
Bmw 335xi/FBO/ black on black/ 6sp manual/Cobb AP/BMS DCI/AA BOV KIT/VRSF DP'S/VRSF 7'FMIC /FULLY CATLESS/H&R sport springs/ 19' ac schnitzer wheels.
03-08-2014, 08:06 PM | #5 |
das Eichhörnchen
46
Rep 279
Go to ECS tuning, enter your car's information, and just browse parts that match your car. They have most pictures too and I received extremely good service every time.
I recently had a clutch job done (went with a OEM 335is clutch from ECS), turns out my clutch was like new but something was wrong with the flywheel. So I ended up having to get a new flywheel too. Some information for you: -You have to go with the OEM BMW twin-mass flywheel. Cheapest is around $1000, I needed mine ASAP and my car was apart and I paid $1200 with rush shipping. -You CANNOT use the LUK or ECS brand etc. since those are only for N54 cars up to January 2009. My car is summer 2009 I think, and yours is a 2010 N54, so you will need the OEM BMW twin-mass flywheel #21207590942. Enjoy Last edited by tphss; 03-08-2014 at 08:12 PM.. Reason: corrected flywheel part # |
03-08-2014, 08:09 PM | #6 | |
Rep 34
Yea
03-08-2014, 09:58 PM | #7 |
das Eichhörnchen
46
Rep 279
Yeah I heard that too, but make sure you get the part # I wrote or it won't fit your late 2009. I wasn't able to find the "LUK" version and had to go with the OEM BMW.
03-09-2014, 10:03 AM | #8 | |
421
Rep 1,643
2007 E92 335i MT
03-09-2014, 10:07 AM | #9 | |
Rep 34
03-09-2014, 04:46 PM | #10 |
112
Rep 2,856
Drives: 2011 335is E93
Have you guys considered resurfacing? I believe it can be done once before having to replace the DMFW.
Speciality shop can usually do it from $120-160 |
03-09-2014, 05:55 PM | #11 |
Reborn
87
Rep 1,217
03-09-2014, 06:36 PM | #12 | |
Rep 34
03-09-2014, 09:32 PM | #13 | |
das Eichhörnchen
46
Rep 279
When installing the new clutch/flywheel I also changed the transmission oil (with oem fluid) and installed e46 M3 transmission mounts (which are identical to the stock ones just a little stiffer compound). Shifting feels smoother, and as far as the 335is clutch, it feels exactly like the stock one with the same weight and feedback. |
03-09-2014, 09:36 PM | #14 | |
das Eichhörnchen
46
Rep 279
You cannot know if the flywheel is good until you take it off and try to move it around. In many cases it is possible to machine it and use again. |
03-09-2014, 09:41 PM | #15 |
Reborn
87
Rep 1,217
I bought a new DMFW and out in an ACT clutch. It only held for about 5k miles, after which I had it resurfaced and installed a Spec 2+. Lux doesn't sell the 2010, 6-bolt DMFW directly, so you're looking at $1k for a new one or $100 including shipping to have it resurfaced. The choice was simple to me.
03-09-2014, 09:58 PM | #16 | |
Rep 34
03-10-2014, 01:00 PM | #17 | ||
112
Rep 2,856
Btw, I resurfaced mine on my 08' 335i E93 at about 88k km and with the new clutch, it was smooth as butter and ran like bran spanking new. Just make sure to get a good mechanic to check it out once it out of the tranny and decide if resurfacing is your best option. |
03-10-2014, 04:59 PM | #18 | |
3441
Rep 79,211
For those looking for a budget friendly solution simply seek out the LUK Flywheel which is an OEM manufacturer of the Dual Mass Flywheel. Then pick up something like the Spec 2+ or whatever you need from us. Win/Win combo. 2/2009 and later vehicles require 6 bolt. 2007-2008 and up to 1/2009 requires 8 bolt. On our site when you checkout with your manufacturing month and year we select the appropriate clutch for you if you end up getting the aftermarket single mass flywheel. (Spec clutches only). |
03-10-2014, 08:10 PM | #19 | |
Reborn
87
Rep 1,217
I took my first one to a local place as they F___ED it up! |
03-13-2014, 10:33 PM | #20 |
Gunny
30
Rep 623
Drives: '07 E90 335i 6MT, 2016 F10 535
Ghost, how did you like the results from having your OEM DMFW resurfaced by Clutch Masters? I live about 90 minutes from their shop and am thinking about having them install a new clutch and resurface my fly wheel.
2007 E90 335i 6MT, ZSP, Nav, PDC, CA, Montego Blue, Terra Dakota leather, CDV, clutch-stop, E46 M Shift Knob, Logic HVI, JB4 PnP, MS 3" downpipes, Koni Yellow adjustable sport shocks, RE 12mm(f)/BMS 15mm(r) spacers, Blacklines, LUX 5.0 LED halo ring lights, DAEOS (Vista) harness, GP Thunder 7500k fogs, 35% sides-20% rear tint, matt black kidney grill, matt black 335i trunk badge
03-14-2014, 09:35 PM | #21 |
Reborn
87
Rep 1,217
Their resurfacing was picture perfect. Been riding with it for over 10k miles with no issues. With spec 2+ it holds all the power (ACT would slip before) and drives/sounds like stock. I will go tanks route again if/when I need too swap clutches.
