03-07-2014, 01:12 PM | #1 |
19
Rep 65
cabin filter- which direction
All,
Which way does the air flow through the ducts? I'm replacing my cabin filter and the arrow on the filter must match the direction of the airflow. I can't tell which was is right |
04-18-2014, 10:08 AM | #2 |
25
Rep 131
Drives: BMW
Garage List 2018 BMW i3 Rex [0.00]
2016 BMW F20 M135i ... [0.00] 1999 BMW Z3/E36 - 1.9i [0.00] 2004 BMW Z4/E85 - 2.5i [5.00] |
Were can i find this cabin air filter, i just bought a oem replacement but do not now were i can find it in the car
If i now were to look for it i can answer your question, maybe i can take a picture of it for you |
04-18-2014, 10:27 AM | #3 | |
19
Rep 312
"It's located under the passenger side under dash cover. If you remove the under dash cover, you will clearly see an arch shaped cover which is part of the climate system. Removing the arch cover will give you access to the cabin filter." |
04-18-2014, 10:33 AM | #4 |
25
Rep 131
Drives: BMW
Thanks, i take a look on sunday and keep you posted
04-18-2014, 11:26 AM | #6 |
19
Rep 312
04-18-2014, 01:07 PM | #7 | |
Rep 93
04-18-2014, 01:55 PM | #8 |
20
Rep 143
Drives: '15 M235i
Based on what they have done with my current car, they will change out the cabin filter annually.
2015 M235i |
04-19-2014, 01:53 AM | #9 |
25
Rep 131
Drives: BMW
Hi all,
I couldn't wait untill sunday, so i just changed the filter and looked wich direction the Arrow was pointed before removal. The Arrow must point at the front of the car :-) |
12-27-2015, 09:17 PM | #11 |
592
Rep 3,870
Flow from front of car to yhe back... Therefore the arrow should point to the back of the car...
More info here http://f30.bimmerpost.com/forums/sho....php?t=1153636 |
05-15-2016, 09:16 AM | #12 |
35
Rep 101
From this tutorial, it seems the arrow is pointing to the front of the car. So the air duct is designed with air flow from the back of the car to the front of the car at the filter location. |
10-16-2018, 02:54 PM | #15 |
967
Rep 2,655
Arrow should point TOWARDS the cabin and INTO the car.
I also verified with FCP Euro as well: "For filters, an arrow marking will generally denote the direction of flow (so in this case the air flows into the cabin, so you'd want that arrow facing into the car)."
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
sspade2466.00 |
10-16-2018, 05:20 PM | #16 |
2466
Rep 5,457
Drives: F30
Interesting how much confusion there is on this simple topic.
10-16-2018, 05:21 PM | #17 |
2466
Rep 5,457
Drives: F30
10-16-2018, 05:35 PM | #18 |
8246
Rep 16,089
I haven't changed mine yet, but the instructions that came with it say the arrow goes in the direction of the airflow. It's possible that the flow is from the rear of the car towards the front, but I can't say until I do change mine.
10-16-2018, 08:54 PM | #19 |
171
Rep 257
You're not kidding. So I looked it up on newtis. Here's the install for my car:
https://www.newtis.info/tisv2/a/en/f...ter/1VnYsiXkj2 Direction of travel? Is that the airflow through the air conditioning unit? Or the direction of travel of the automobile? Then I'm supposed to reverse it?
2021 i3s AC Schnitzer BMW CCA #67486 |
10-16-2018, 08:56 PM | #20 |
731
Rep 1,045
It's the direction of air flow travel, so you should point the arrow towards yourself, as the air is coming out of the vent and into the cabin. At least that's how it was done on all the other cars I've owned.
10-16-2018, 08:58 PM | #21 |
8246
Rep 16,089
agentorange1507.50 |
10-16-2018, 09:04 PM | #22 | |
171
Rep 257
Clear as mud. It reminds me of the Chinglish I had to decipher on some cheap junk I bought at the "orange" home store.
