TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > who is running FBO+METH+ RBs?
      03-07-2014, 10:17 AM   #1
FRMTL2_335i
76
Drives: E92 335i
i get my RBs on monday and the car will be going for surgery the following weekend.
Im trying to find some data regarding:
what type of e85 mixture people are running---
fuel system upgrades (inline walbro or in-tank walbro 455)---
meth settings (additive, nozzle location, how many nozzles) ---
what map (jb4) are you using?
maybe we can all post our settings/mods here and try different things.
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
      03-08-2014, 07:29 AM   #2
FRMTL2_335i
76
Drives: E92 335i
i guess nobody runs RBs here huh?
      03-08-2014, 11:13 AM   #3
Shadow007
64
Drives: 2009 335i coupe monaco blue
I don't have rbs but I do have the vtt stage 2s.
      03-08-2014, 12:06 PM   #4
FRMTL2_335i
76
Drives: E92 335i
that's a nice upgrade as well
Mind answering my questions up top?
do you have any logs to share?
      03-08-2014, 12:40 PM   #5
crimson335
20
Drives: 335i coupe
I use 50% e85/91
Inlinr walbro installed
One meth nozzle on my ER chargepipe, i use cm14(cm10 will do the job)
Additive for meth i use 60-70
With 75 additive i dynoed 530whp and 530tq
      03-08-2014, 05:59 PM   #6
scottp999
133
Drives: 4runner SR5
2007 BMW 335  [9.00]
1) No E85
2) No Fuel System Hardware Upgrade
3) Nozzle is at the elbow before charge pipe, One DO12
4) Use Procede, run upgraded turbo map and backend fuel flash via OFT
93 Octane, 100% meth, about 19-20PSI in mid range 16-17 at top end RPM. Probably running around at 480 whp.
      03-08-2014, 06:18 PM   #7
Brule
Australia
829
Drives: 2007 335i e92 6spd man
What is back end flash suitable for RB's with jb4?
      03-08-2014, 06:51 PM   #8
scottp999
133
Drives: 4runner SR5
2007 BMW 335  [9.00]
I believe Terry has a backend flash that is equivalent. It may be loaded by Bavarian Tech cable, or some other means. Originally i think he had something loaded by COBB, but not sure that is still supported. I have not kept up with those developments.
      03-08-2014, 10:51 PM   #9
Brule
Australia
829
Wrote to terry about it he recommends starting with race flash.
      03-09-2014, 08:02 AM   #10
shmorgan77
shmorgan77's Avatar
17
Drives: BMW 135i
I have rb's, don't run meth but love e85. I put 8 gallons of e85 and 6 of 93 pump. Trying to come out with an e60 mix. I run a 20psi map with the rb's and it pulls like a freight train. I have a walbro 255 inline too keep up with fuel demands but it's not doing it's job. I've put 110 unleaded race fuel in and used the
20psi map and the fuel pressure is better. Expensive though.
      03-09-2014, 02:10 PM   #11
FRMTL2_335i
76
Drives: E92 335i
thank you guys for the answers.
i have been running full e85 since last summer without an issue using walbro 455 setup 3.
meth, i run two cm10 nozzles, one before the ic, and another right after the ic before the charge pipe. after i added meth, the second nozzle actually, my stock clutch barely kept up with it, i felt it pulling a lot stronger in the highway. after the second nozzle i had to keep my additive at around 50, the car felt like it was gonna blow up at high speed/rpms with 60+ additive lol.
i think im gonna run some logs with e85 only when i get the rbs in, and go from there. run some logs, see how things look and start adding meth slowly. i have the 2.2gallon tank from bms but i have to fill it up quite frequently since i added the second nozzle. i bet there is no more carbon buildup around my valves anymore lol.
also, for those who are running RBs, did you get the Thrust upgrade? the turbos i got don't have them, but the turbos are still sealed in the bag and everything. im thinking about sending them back to Rob and having him install the thrust bearing upgrade.
      03-09-2014, 02:12 PM   #12
FRMTL2_335i
76
Drives: E92 335i
is your 20psi map, map6? did terry send it to you?
      03-09-2014, 02:13 PM   #13
FRMTL2_335i
76
Drives: E92 335i
yeah ive been running the race flash since i went full e85 plus meth... during the summer that is, over the winter i went with map 5 and no meth of course lol.
      03-09-2014, 03:15 PM   #14
scottp999
133
Drives: 4runner SR5
2007 BMW 335  [9.00]
Originally Posted by FRMTL2_335i View Post
..., for those who are running RBs, did you get the Thrust upgrade? the turbos i got don't have them, but the turbos are still sealed in the bag and everything. im thinking about sending them back to Rob and having him install the thrust bearing upgrade.
I trust Rob's comments on the thrust upgrade:
08-17-2013, 08:29 PM
Originally Posted by brendan
Rob,
What is the thrust upgrade on your website?
Its pretty much a waste of money. However there are some who run around believing it converts a turbo to an everlasting device, so for those people rather than trying to convince them otherwise I just offer the parts for them.
Rob
      03-10-2014, 10:45 AM   #15
FRMTL2_335i
76
Drives: E92 335i
Rob,
Rob
thanks man, yeah good thing i didnt send them out. lol he is a pretty straight forward guy.
      03-10-2014, 12:01 PM   #16
AS4EX
N
31
Drives: X3
You'll still lose to my stock turbo's and no meth
      03-10-2014, 12:24 PM   #17
N3m3sis
30
Drives: 335i
Bwhahaha what he said
Looking forward to seeing you out and about this summer. Maybe steal a little ride in your car?
Good luck with the swap!
      03-10-2014, 12:50 PM   #18
FRMTL2_335i
76
Drives: E92 335i
you better keep ur mouth shut around here! lol.... sleeper mode engaged this summer.
      03-10-2014, 05:17 PM   #19
TheSpilDog
11
Drives: 335i
I'm running
procede custom map
ecu flash
94 octane
50/50 meth
rb's
fbo
485 whp and 500 lbs torque
without meth
445 whp
      03-10-2014, 05:46 PM   #20
Dmacc
200
Drives: 2011 BMW 1M
Originally Posted by TheSpilDog
I'm running
procede custom map
ecu flash
94 octane
50/50 meth
rb's
fbo
without meth
445 whp
Nice! 445whp on 94 octane isn't bad at all!
thanks to MGallop
      03-10-2014, 05:54 PM   #21
TheSpilDog
11
Drives: 335i
yes we were very happy with the results...
      03-10-2014, 06:29 PM   #22
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
before my rear RB turbo took a shit, I was running a 7 gallons of E85 + 100% meth on a single CM10 (FBO).
No fueling issues at all. Trims looked great. You could get away with a E33 blend (5 gallons of E85) but anything more than that you'd need either an LPFP upgrade or meth.
E90 LCI N54 6AT
