03-05-2014, 07:18 PM | #1 |
Facetious
109
Rep 530
What after-market wheels will be close in size to OEM?
With a wide variety of after-market wheels available, we might want to compile a list of the ones that will be a direct swap of the stock ones (while maintaining the same tire size).
We can use this calculator to confirm the sizing: http://www.1010tires.com/Tools/Wheel...ulator#Results The data comes from the original thread: http://f80.bimmerpost.com/forums/sho...d.php?t=945713 Summer wheels - 9x18 (ET29) +10x18 (ET40), Style 513M - 9x19 (ET29) +10x19 (ET40), Style 437M Winter wheels - 8.5x18 (ET27) +9x18 (ET29), Style 640M - 9x19 (ET27) +9x19 (ET29), Style 641M I'll start OEM: M437 front - 19x9 (29) rear - 19x10 (40) Aftermarket VMR VB3: front - 19x8.5 (20) - inner clearance: +15mm, outer position: +3mm rear - 19x10 (38) - inner clearance: +2mm, outer position: +2mm VMR V710: front - 19x8.5 (35) - inner clearance: same, outer position: -12mm (spacer will be needed) rear - 19x10 (38) - inner clearance: +2mm, outer position: +2mm
Current: '15 BMW M4 (6MT), '08 HD Dyna Street Bob
Previous: '06 BMW 330Ci; '06 Mercedes CLK-350; '04 Acura TL A-Spec; '95 BMW 318ti; '92 Mercury Cougar; '94 Honda Accord Last edited by filip75; 03-05-2014 at 07:28 PM.. |
