BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Weird R-Comp wear
      11-13-2007, 11:49 PM   #1
leftcoastman
52
Drives: 335i
Weird R-Comp wear
I took my Victoracers off tonight to examine the damage from two days of hard track abuse.
With stock 335i suspension with H&R rear sway, on 17x8.5 wheels, I am getting a most unusual wear pattern on the 255-40-17 tires.
First, the rim size is the minimum recommended for the 255 tires, but that doesn't explain the wear pattern. Given the stock front camber, you would expect the OUTSIDE to get beat to hell. But as you can see from the attached pics, the insides got worn down and while the tread is more "gone" from the outside, the outside appears to have more rubber left!
The left side of the tire, as seen in the attached pics, is the outside edge. The tires were rotated throughout the weekend, and they all look like this. Thoughts?
      11-14-2007, 08:09 AM   #2
S4to335
431
Drives: 2014 Audi A4 / 91 Track Miata
Let me take a pic of my pilot sport cups for comparison...
Car is now gone .... :-(
      11-14-2007, 08:12 AM   #3
2e9x's
2e9x's's Avatar
50
Drives: 335i ED 7/07
What pressures were you running? Did you measure the tire temps at all?
2010 Evo X - silver with a big, stupid wing on the back
2009 VW CC - Black/Black - with a 2011 328i on order to replace it - ED 8/1/11
      11-14-2007, 09:12 AM   #4
leftcoastman
52
Drives: 335i
Pressures were 40 hot front and 42 hot rear. Any less in the front and I'd be scrubbing the logos on the outside.
Any less in the rear and I'd be rotating like a top. Note the front and rear have pretty different camber settings - but I was rotating the tires around all weekend.
      11-14-2007, 09:48 AM   #5
Hegemony
Fast Like Tiger
Hegemony's Avatar
13
Drives: 07 M Coupe
I will take a pic of my Nitto NT01's tonight also. They've been through 3 track events now.
Left,
I know you rotated them, but what are the characteristics of the track you went to? We should all post our alignments as well.
      11-14-2007, 10:01 AM   #6
leftcoastman
52
Drives: 335i
Heg - the track was rougher than a teenage kid's face.
My alignment is bone stock. Haven't changed a thing. I did notice that the rear sway "forces" the alignment to retain it's negative camber. On my street tires, the inside edge of the rears got corded before anything else.
Of course, for the front street tires, I corded the shoulders first - two sets to be exact.
Who loves understeer?
      11-15-2007, 10:32 AM   #7
elbert
digging for gold
elbert's Avatar
Drives: Ford Tempo GL
Looks like tire pick up to me, some of which is still there and the rest got scrubbed off
      11-15-2007, 11:02 AM   #8
leftcoastman
52
Drives: 335i
Nah that was just on the "lip". The whole outside tread chunk is a few mm higher than the rest of the tire.
Anyone get their pics taken yet?
      11-15-2007, 11:21 AM   #9
elbert
digging for gold
elbert's Avatar
Oh I see, your picture is kinda crooked.
Did you consider the possibility that the wear might have occurred when the tires were in the back?
      11-15-2007, 11:31 AM   #10
leftcoastman
52
Drives: 335i
Yup, but generally I spin one rear tire. Although I rotated, I only did it once so only two tires ever got put in that offending position.
All tires have this weird staircase wear pattern.
The ODDEST part is that the "higher" outside edge is devoid of tread blocks now while the inside edge (lower in absolute rubber depth) still has tread blocks.
      11-15-2007, 11:51 AM   #11
elbert
digging for gold
elbert's Avatar
You're probably spinning the rear tires more than you think.
I'm willing to bet the staircase pattern is because you are running minimum wheel width. It's minimum, not optimum, as it allows a lot more sidewall flex.
Out of curiosity, do you shave the tires?
Are the channels of equal depth when new? Or maybe some tire pick up filled in the tread?
      11-15-2007, 12:22 PM   #12
leftcoastman
52
Drives: 335i
Yes, the minimum wheel width. And no, not shaving the tires.
And I'm an idiot - I just realized that the outer blocks had significantly shallower grooves than the rest of the tire.
Maybe what's happening is that the outer wears to "slick status" quickly and now has a ton of rubber on the road. The center/inner is still running on treadblocks so wears down a lot faster. But only thing is that I haven't heard this problem from other people running this tire.
      11-15-2007, 12:41 PM   #13
HyperM3
Too many Alex's, from now on, call me Beaufort
341
Drives: See Sig
Were they properly heat cycled?
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip
16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone)
07 335i(gone)
      11-15-2007, 12:44 PM   #14
leftcoastman
52
Drives: 335i
Yes
      11-15-2007, 12:46 PM   #15
HyperM3
341
Drives: See Sig
Yes
Could be like what you said you noticed. That the tires were designed for the shoulders to wear quicker so they get slick and put down more of a solid patch.
13 HD FatBob
07 335i(gone)
      11-15-2007, 01:43 PM   #16
S4to335
431
He breathed really hard on them...
      11-15-2007, 01:47 PM   #17
leftcoastman
52
Drives: 335i
Nah - I rubbed the tires with my hand. You know how when you rub your hands together they get warm? Kinda like that.
      11-15-2007, 02:39 PM   #18
davig
davig's Avatar
Drives: 335i coupe
My Victoracers on my RX8 looked like that initially. I got more even wear and better performance when I lowered the pressure.
335i coupe, pss9s, F1 GD3
C5 Z06
      11-15-2007, 03:03 PM   #19
leftcoastman
52
Drives: 335i
That's comforting to hear. Did you get squirm when running really low pressures? And when you say, what's the hot pressures?
Also, did you have good neg. camber up front? My camber is so bad that I feel like I'm going to rub the wheel face on the ground, lol.
      11-16-2007, 10:45 AM   #20
davig
davig's Avatar
Drives: 335i coupe
RX8 is camber challenged as well. I have Tein coilovers which improved things a bit. I start with 34 cold pressure all around on 245/40/17s and bleed off a bit if it gets >40 hot. It's a lighter car so I don't think you can compare pressures. On hot days I get a bit of squirm after about 12 miles. Have you tried using a pyrometer to messure temps on outside middle and inside of all tires immediately on returning to the pits? You might be hotter in the middle. I had to do quite a bit of experimentation to get even temps.
C5 Z06
      11-16-2007, 11:37 AM   #21
sg335
52
Drives: 335i
That does not look too bad. It is typical for the tread just prior to a water channel to have some more uneven wear as the forces flex the rubber during cornering. Right of the channel wears in and left of the channel wears out and up.
Here are pics of the Nitto's after this weeks event and 6.5 hours of track driving with 500+ miles of street driving. First pic is newly scrubbed non shaved tire with six laps on them. Next is front tire and last is rear tire.
      11-18-2007, 05:14 PM   #22
Hegemony
Fast Like Tiger
Hegemony's Avatar
13
Drives: 07 M Coupe
Here are my NT01's after 5 days worth of sessions. I'm still staggered, so I can't rotate, and the last track I ran at is hell on the right side.
Search this Thread:
Advanced Search
