02-28-2014, 10:34 AM | #1 |
12
Rep 24
BMW F30 316 I 04/2013 engine N13 , Turbo get too red and hot
Dear Mates ,
please can someone help me with this issue , I am surprised and scared I have my car BMW F30 316 I 04/2013 engine N13 when I look on my engine I found that the car turbo is getting too red and hot which scare me a lot . I ve took the car to the BMW dealer : they change Turbo , Intercooler , Lambda sonde and nothing changes it still the same issue ! please advise what should I do ? with kind regards Adel |
02-28-2014, 12:49 PM | #4 |
12
Rep 24
02-28-2014, 01:32 PM | #5 |
50
Rep 1,730
This is an engine not offered in NA, so most on this board will not be familiar with it. I would research it a bit and see if you can find message boards from other makes that run this engine - looks like it was co-developed by BMW and PSA Peugeot Citroën, a lot of Citroën cars have it, as seen here:
http://en.wikipedia.org/wiki/BMW_N13...e_turbocharged |
02-28-2014, 02:07 PM | #6 | |
12
Rep 24
02-28-2014, 02:30 PM | #8 |
50
Rep 1,730
That engine is also a lot more overworked I'd bet. Ford had problems with their 1.6T engine on the escape, mainly because it was overworked for that application. A diesel engine should be better in a downsized application - more usable torque. Less high end revving range to strain the turbo.
02-28-2014, 02:33 PM | #9 |
12
Rep 24
02-28-2014, 04:35 PM | #10 |
129
Rep 536
They weren't BMW's in particular but a 13T Hyundai, an upgraded td05-16g Genesis and also 19T turbos. I.'ve always thought of it being normal almost how you see manifold get as red from heat after a nice run.
But that is my 2 cents. |
02-28-2014, 05:44 PM | #11 |
72
Rep 941
I've had a 316i service loan car for almost 2 weeks. I'm surprised there's an engine in there at all actually
Next time it goes for a run I'll check the turbo and report back. |
03-01-2014, 04:57 AM | #12 |
12
Rep 24
03-02-2014, 05:12 AM | #14 |
12
Rep 24
03-02-2014, 10:14 PM | #15 |
Rep 36
I believe that's normal. Turbos are awesome and scary.
Although on the more powerful models you wouldn't see it as much because you don't need to give it full throttle so much. |
03-03-2014, 02:15 AM | #17 | |
19
Rep 256
I had the N18 (What they call it in the MINI) in a MINI Cooper S with 184 hp. It got very hot, the fan and water pump was often on when I left the car. Never saw it glow like that though. But I'm not sure I looked either. |
03-03-2014, 02:25 AM | #18 |
19
Rep 256
I think you should do a post in the 1-series (F20/F21) forum here as well. There are many more with these engines. I know that one member here called ovekvam he has a 116i M-Sport which he races on track with now and then.
03-03-2014, 08:12 AM | #19 | |
50
Rep 1,730
03-03-2014, 08:21 AM | #20 | |
19
Rep 256
03-03-2014, 12:15 PM | #21 |
242
Rep 735
The speed you were driving the the outside temperature are not the most important factors. What's important is how much acceleration did the car undergo. The temperature of the turbo is very high compare to the ambient. 9 degrees or 25 degrees outside doesn't make a difference.
Current: BMW F32 435iA M-Sports; BMW E92 M3, M-DCT; Mercedes W221 S550 4matic; Ford Fiesta ST; Nissan Silvia S15 Spec-R Retired: BMW E93 323iA; BMW E85 Z4 3.0i, SMG; Lexus IS 250 AWD; Lexus GX 470; Mercedes W203 C230 Sportscoupe; Peugeot 206 S16; Peugeot 206 RC |
03-04-2014, 04:56 AM | #22 | |
12
Rep 24
I need to clarify to you just that I mentionned the ambiant temp is arround 9 degree C actually and in Summer it can reach 40 Degree C , so it can be worst condition for the Turbo to get cooled are there any additional tools to cool my Turbo ? regards Adel |
