newbie easy questions1 - shifting/exhaust
02-27-2014, 08:49 PM | #1 |
11
Rep 77
Drives: 2015 535i xdrive, 2014 x5 35i
Picked up my pre-lci 335xi sedan this week, so i'll probably have questions until i figure everything out. Thanks for your help in advance.
1) Took it to work for first time today. After starting, i noticed exhaust only coming out of passenger side pipe. Driver side had nothing at all coming out. I put my hand over the pipe end to make sure. Could this be normal? 2) Is there strain/wear from shifting an automatic from drive to sport while you are driving the car? When i'm cruising down highway, drive works good, but the second there is traffic and i need to zoom around, i want sport. I can see myself wanting to shift back and forth a lot during my normal driving, so want to ask if doing this all the time will be hard on anything? Thanks |
02-27-2014, 09:05 PM | #2 |
56
Rep 1,464
Drives: 2009 BMW 335xi
1. This is normal. There is a vacuum operated flapper valve in the d side exhaust. search golf tee mod on how to defeat this.
2. No problem there although there are wires in the shifter that can break over time. simple to fix if that happens though. |
02-27-2014, 09:15 PM | #3 |
30
Rep 644
Like gta said. It is normal on the exhaust. It open up at speed. If you wait about a minute after start up you will hear and see it open up.
On the shifter you can switch back and forth all you want. |
02-27-2014, 09:37 PM | #4 |
Rep 45
02-28-2014, 11:37 AM | #5 |
69
Rep 1,766
1.) Completely normal.
2.) No so shift modes to your heart content.
JBD @ 100% | KW ST Coilovers | M3 rep. front bumper | 888Concepts AE Upgrade | GP Thunder 7500k fogs | Cyba 4" carbon tips | BSW Stage 1 | APEX ARC-8 W/ Michelin PSS | Ziza LED interior | Weisslicht LED side lenses | Sprint Booster | Euro side mirrors | M-Sport semi-conversion | Coded | LOTS of carbon fiber
02-28-2014, 09:58 PM | #7 |
11
Rep 77
thanks all. i don't want my car louder, so won't be doing mod. interesting though. does that mean with the mod, exhaust will immediately flow out of both pipes?
