2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Anyone here use Plastidip?
      02-24-2014, 10:37 PM   #1
PhilT3
6'0 / 250lb
PhilT3's Avatar
137
Drives: 2014 M5
Dipyourcar.com
Seems pretty legit.
Build: '14 M5 - Space Gray / Full Sakhir Orange / Alum Trace / Black 343's / Exec / Driver Assist / LED
Mods: SunTek CXP tint - Vinyl-wrapped door handle chrome - Macht Schnell 12mm spacers - Pedalhaus pedals - iND Cosmetic Package - Polished 90mm exh tips - Coded by v12 - 21" HRE S107's polished lip/black center
      02-25-2014, 06:20 AM   #2
dblock2151
22
Drives: '11 550i Msport DG
You're lucky because one of the best installers in the country is right in Philly. They're called Kustom Dips and they are really setting the bar as far as custom colors and application of the plasti-dip. The prices aren't too bad either!
      02-25-2014, 09:25 AM   #3
Sunny 528i
49
Drives: 2012 528i
yup i plasti-dipped the chrome trim around the windows! awesome stuff and it lasts.
      02-25-2014, 10:00 AM   #4
PhilT3
6'0 / 250lb
PhilT3's Avatar
137
Drives: 2014 M5
Excellent. Thanks!
      02-25-2014, 12:08 PM   #5
Akkord29
57
Drives: F80, G20, E46
Got pic's? Did you use matte black?
      02-25-2014, 12:43 PM   #6
LACSTER
756
Drives: Hybrid
I plastidip my grills once and they turned out great.
      02-25-2014, 01:39 PM   #7
Sunny 528i
49
Drives: 2012 528i
yup here you go: matte black
      02-25-2014, 03:49 PM   #8
PhilT3
6'0 / 250lb
PhilT3's Avatar
137
Drives: 2014 M5
Man..... You see them all the time, but boy do those M5 wheels really suit the F10's lines!
      02-26-2014, 10:24 PM   #9
ajandhek
12
Drives: none
U should plasti dip your reflectors white as well
      02-27-2014, 09:09 AM   #10
Sunny 528i
49
Drives: 2012 528i
That's the same thought I had when i saw the M5 wheels on another forum member's F10, Just fell in love with the way they look on the car
      02-27-2014, 09:14 AM   #11
Sunny 528i
49
Drives: 2012 528i
Next on my to-do-list
Just finished up painting the calipers red. I also just purchased and ENET OBDII wire to program the car but still trying to learn the coding process. Its abit confusing trying to find this token and pin thing to use Esys
      03-29-2014, 01:30 PM   #12
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
Honestly if you hae access to FlexiDip, which is Rustoleum's version of Plasti Dip, I would use that. It was recently released at Home Depot and the results are much smoother. It comes out like primer, nice and flat. No roughness at all like Plasti Dip.
      04-02-2014, 07:06 PM   #13
top6491
MSGT USMC (Ret)
18
Drives: 2012 AW F10 535i M-Sport
2012 BMW 535i  [0.00]
PLasti-Dip is pretty cool and easy to use. I did my rims flat black and they look great. I'm now trying the anthracite metallic and will post pics soon. Don't be shy, go for it, you can always peel it off, but it's better is the coat is thicker if you are going to peel, like 2-3 coats minimum.
      01-06-2015, 02:09 PM   #14
843f10
12
Drives: alpine white f10 535i
ive done a ton with the plastidip. i love it
5post
