11-12-2007, 06:23 AM | #1 |
33
Rep 188
iPod Cable...
i know this has been brought up in other related threads but there have been many varied replies. Can someone finally and definitively answer the question...Does the cable supplied with your ipod for use with the pc allow your car to read and play all the tracks or is there another cable you have to buy?
11-13-2007, 11:11 AM | #3 |
35
Rep 563
Drives: 2007 E92 M3
Hi Chris - Ignoring the fat that MY iPod does not seem to work, if this is the case (and I'm sure your not making this up), why did they tell me to buy a new cable... do you get any extra functionality at all with the BMW cable?
Now that I have finally got the Universal Remote Control to work, this iPod nonsense is the one remaining fly in the ointment... EDIT: OK, my impatience has been getting the better of me... It works OK with the original cable (although older models will not charge on USB), but you need to give it a few minutes for the song-titles etc. to upload to the head-unit (the bigger the disk, the longer it will take). The iPod used like this works as a gigantic USB stick: the head-unit merely downloads from the file system on the disk only (which I presume must be FAT32/NTFS format) .mp3 files are browsable, all directories on the disk are visible, the audio is decoded on the DRM-compliant head-unit. The one gripe so far is that, unlike iTunes etc., it groups all the "The ####" bands together under 'T'. My suspiscion is that the BMW cable will work as follows: 1) The device itself will be recognised as an iPod and control instructions will be sent directly to the device by the head unit. 2) The decoder on the device itself will be used rather than the .mp3 decoder on the head unit (this means that you will not have DRM problems and you can play AAC files) 3) The consequence of 2) is that you must use the auxillary input for audio I don't have any answers on Mac-compatibility I'm not going to bother with the BMW cable because I don't need it, but I'm miffed that it wasn't supplied as standard. Now all I need to do is go and collect the new iPod my mate brought me back from NYC. Last edited by 13eastie; 11-13-2007 at 01:21 PM.. |
11-13-2007, 03:35 PM | #4 |
578
Rep 2,104
11-13-2007, 03:41 PM | #5 | |
578
Rep 2,104
The headunit is used to decode (or playback) the mp3, however it doesn't contain any DRM decoding capabilities, so therefore will not playback drm mp3 tracks. |
11-13-2007, 05:15 PM | #6 | |
35
Rep 563
Drives: 2007 E92 M3
Yes, the only way to play protected tracks will be to use the BMW cable - by "DRM-compliant", I mean't that the head-unit's decoder follows the DRM rules. |
11-14-2007, 03:31 AM | #7 |
33
Rep 188
I have planned ahead on this issue and asked my dealer to order me whatever cable is needed before i collect the car. He mentioned that there might be a charge - and i told him i hoped he was joking. He agreed to drop the charge, so as soon a get my car i will let you know what the story is with the mythical cable...
11-14-2007, 12:04 PM | #8 |
35
Rep 563
Drives: 2007 E92 M3
"Gapless" playback with the regular cable isn't...
I'm going to ask my dealer to send me the cable FOC. |
01-10-2008, 08:19 AM | #9 |
33
Rep 188
finally got the correct cable from my dealer today.
When i was using the cable that comes with the ipod some playlists and certain albums were missing. With the new cable all this is solved. The cable connects to the ipod and then connects to the usb AND the aux input. They normally charge €60 for this!!!! needless to say i told him where he could go with his €60. |
01-10-2008, 09:00 AM | #11 |
135
Rep 1,274
Are you guys sure that the ipod is not the one that plays the mp3 and just sends the signal to the car?? Maybe that's why it need both connections:
USB: controls Audio Jack: audio signal played through the iPod. In general, with the normal USB cable, you are not able to read the mp3 files loaded with iTunes into the iPod. (unless you use a program such as copy pod). All of this sounds reasonable if you consider that you shouln't need the audio connection. |
01-10-2008, 10:26 AM | #12 | |
578
Rep 2,104
The ipod is used to playback the audio, as only the ipod can playback the DRM files. BMW didn't have any other choice, as apple normally dont license out their DRM. |
01-10-2008, 11:50 AM | #13 | |
135
Rep 1,274
I read in the manual (recently posted) that the iDrive will recognize the song info on a normal drive so that's a great option (and cheaper, as the ipod adapter is 300 bucks!!) |
01-10-2008, 11:52 AM | #14 |
135
Rep 1,274
01-11-2008, 04:17 AM | #15 |
33
Rep 188
Originally i was using the standard PC connection ipod cable. All controls were available and most of the music was there but not all of it. About 80% of my downloaded itunes music was showing with about 20% simply not visible. The directory structure also seemed to be a bit messed up.
The BMW cable simply cleared everything up and sorted the missing music. Quality of playback was the same with both cables. |
01-29-2008, 10:37 AM | #16 |
156
Rep 1,430
What's different about the BMW cable? Does it not plug into the USB adapter like a normal iPod cable?
01-29-2008, 10:45 AM | #17 |
Moderator / European Editor
1494
Rep 6,755
01-30-2008, 08:33 AM | #18 |
156
Rep 1,430
But can't you buy a BMW cable that doesn't require AUX audio?
01-30-2008, 10:02 AM | #19 |
1494
Rep 6,755
Don't think so. Playback of DRM protected stuff works only via Aux In. You can use a std USB cable, though. Works even with an iPod as long as you're not playing DRM protected songs. (Didn't try that out myself, but others have said so).
Best regards, south |
01-30-2008, 02:39 PM | #20 |
61
Rep 924
Drives: Ford Falcon Ute, Ducati 1198S
This is the iPod cable.
I asked to have it included when I pick up my car, better than a bottle of wine or a BMW shirt I will never wear..... |
01-30-2008, 05:17 PM | #21 |
44
Rep 544
got a part number for that?
08' e92 M3 6MT // Rogue SSK // B&B Tri Flow Exhaust // AA air filter // Mod Carbon Skirt extensions // Amuse Front/Rear Bumper // Amuse Trunk // Gloss Black Grills w/ M colors // gloss black side vents // M5 Stick with IND custom stitched boot // Carbon Firber wrap steering wheel trim // Avant Garde M364 20' (street) // Advan RS 18's (track) |
02-20-2008, 01:59 PM | #22 | |
1641
Rep 2,775
Drives: F95 X5MC
Does anyone know what the BMW part number is?
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
