Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > about to order new wheel\tires, thoughts?
      02-19-2014, 06:39 PM   #1
madbim
madbim's Avatar
32
Drives: 08' E90 335xi
Wanted to get some opinions before I pull the trigger, car is an 2008 335xi. I understand the 235/265 combo would be closer in overall height, but I'm not a fan of the stretched look. Are the tires sizes listed below safe to run on an XI?
VMR VB3 Gunmetal
19x9.5 et 33 front
19x10 et 25 reat
Conti ExtremeContact DW
245/35/19 (808 revs per mile)
275/30/19 (818 revs per mile)
      02-20-2014, 01:42 AM   #2
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
VMR VB3 Gunmetal
19x9.5 et 33 front
19x10 et 25 reat
Well the recommended diameter difference is under 1% and 245/275 have 1.004% difference. So it's basically too much or just on the borderline.
Here is e90 with those wheel sizes, but 235/265 setup. Don't know the tyre brand. http://www.e90post.com/forums/showpo...89&postcount=3
      02-20-2014, 08:54 AM   #3
madbim
madbim's Avatar
32
What's more inportant to go by, rolling diameter or tire size?
      02-20-2014, 09:21 AM   #4
FCobra94
Guest
n/a
Drives:
The obvious answer is rolling diameter. You can put whatever tire size you want front and rear, as long as they fit; that doesn't matter. What does matter is the rolling diameter difference between the two "axles."
If you don't like the stretched tire look then don't get such wide wheels to begin with. Even with your proposed setup, 245 will look stretched on a 9.5" wheel. For that reason, you might want to rethink your setup...
      02-20-2014, 09:40 AM   #5
jon_335
15
Drives: 2007 BMW 335i
I have Hankook V12 235s on 8" wheels and the sidewall is pretty much straight up and down. A 235 on a 9.5" wheel will be stretched.
2007 BMW 335i | Garner, North Carolina
      02-20-2014, 10:26 AM   #6
madbim
madbim's Avatar
32
The tire calcular here doesn't take rolling diameter into considerdation, this is obvisouslly the most accurate way to calculare the percentage difference. The Bridgestone RE760 in the tire size I want have a closer rolling diamter perhaps that tire is better suited for my needs?
      02-20-2014, 10:46 AM   #7
Nitrous Garage
Nitrous Garage's Avatar
207
Drives: E82 135i / E92 328i / E60 550i
It does. It is posted in the Percent Difference box. In red
      02-20-2014, 11:37 AM   #8
FCobra94
Guest
n/a
Drives:
Use this site if it's easier for you to understand with better visuals:
http://www.miata.net/garage/tirecalc.html
