02-16-2014, 01:18 PM | #1 |
658
Rep 1,480
Drives: 2020 M340Xi (G20)
Actual PSI Displayed & Hampton Roads Coder
Hi,
Have a 2014 328i with Tech package. Thought I have read that you can code the car so that the actual tire pressure (PSIs) can be displayed on the tire pressure monitor screen. Is that the case or do I need special sensors? BTW, anyone know of someone who does coding down here in the Virginia Beach/Norfolk/Hampton Roads Area? |
02-16-2014, 08:08 PM | #2 |
10487
Rep 40,951
Drives: 2018 Alpina B6 650ix GC
You need 609 Navigation Professional and 2VB Tyre Pressure Control (TPC), then you can code it to enable Pressure and Temp readings in addition to the color code display.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
02-23-2014, 11:50 AM | #3 |
658
Rep 1,480
Well, I know I have the Professional Nav as it was part of the tech package.
How do I tell if I have this 2VB package? If not, what does adding it entail? Thanks |
02-23-2014, 11:58 AM | #4 |
10487
Rep 40,951
2VB is actual sensors in the valve stems, and transmitters to relay the data.
Since you have U.S. Spec'd car, you should have 2VB.
02-23-2014, 01:37 PM | #5 |
658
Rep 1,480
Great! So all I have to do is get the coding done to display the actual tire pressure on the TPM screen of the iDrive -- is that correct?
Thanks |
02-23-2014, 04:34 PM | #6 |
10487
Rep 40,951
Yes. With 2VB, it just needs coding.
02-23-2014, 04:45 PM | #7 |
658
Rep 1,480
One last request. Can you send me the info to make this code change?
Again, very much appreciate the help! Al |
02-23-2014, 06:33 PM | #8 | |
10487
Rep 40,951
You will specifically need to code Head Unit (HU_ENTRY, or HU_CHAMP or HU_CIC, or HU_NBT) for RDC_SAFETY = aktiv.
03-16-2014, 01:42 PM | #9 | |
658
Rep 1,480
In fact, I just coded: HU_NBT/3001/EXBOX/RDC_SAFETY to aktiv (I have Tech pkg so it's NBT rather than CIC) and it works like a champ, displaying tire pressure & temperature for each tire on the TPMS screen Thank you very much!!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
03-16-2014, 01:53 PM | #10 |
10487
Rep 40,951
The Tech Package is why you have 609 Navigation Professional, but it has nothing to do with NBT versus CIC. You have NBT because F30 model year 2014 replaced CIC with NBT. You can't get a 2014 with CIC.
03-16-2014, 02:07 PM | #11 | |
658
Rep 1,480
BTW, I also coded Weatherband Radio: HU_NBT/3001/AUDIO_TUNER_TRAFFIC/RADIO_WEATHERBAND to aktiv. Nothing shows up on the list of radio options; is this one of those you have to wait a while for? Again, your help has been tremendous!
Al
03-16-2014, 02:24 PM | #12 |
10487
Rep 40,951
WEATHERBAND works on CIC, but it doesn't work on NBT for some strange reason.
03-16-2014, 02:43 PM | #13 |
658
Rep 1,480
Oh well, will take that off my list
Al
03-16-2014, 03:33 PM | #14 |
Rep 83
Are you sure Navigation Personal required? I had it coded yesterday on a 2014 without nav and I can see the individual tire pressure. Or is this something else?
03-16-2014, 09:27 PM | #15 |
10487
Rep 40,951
It was at one time. It could be newer head units are capable of it now.
Do you have HU_ENTRY or HU_CHAMP?
03-17-2014, 09:02 AM | #16 |
Rep 83
No idea, I didn't do the coding. Is there a way I can check without having cables and software?
03-17-2014, 10:32 AM | #17 |
10487
Rep 40,951
Probably, but I don't know how myself. I only know how from reading the car with E-Sys.
03-17-2014, 12:36 PM | #18 |
Rep 83
03-17-2014, 01:04 PM | #19 |
10487
Rep 40,951
Ok, thanks. If it works with HU_ENTRY, then it should work with any Head Unit.
03-25-2014, 10:59 AM | #20 |
36
Rep 465
Will someone take a pic of where/how it displays. That's a pretty neat function, it just adds that data to the TPMS screen of the center idrive screen ? Wanting to see if it's worth it to finally get my car coded with all these things.
13 335i Msport
89 E30 325is 5spd |
03-25-2014, 11:06 AM | #21 |
10487
Rep 40,951
04-17-2014, 01:10 PM | #22 |
630
Rep 1,649
this is awesome. my brother in law's MDX shows it from the factory and wondered if it was possible in a BMW. can't wait to get this done at some point.
