02-10-2014, 12:33 PM | #1 |
19
Rep 91
LED Fog Light retrofit stay dim when off
Hi
Just wonder if someone can help me, fitted LED fogs to my F30 today and done the coding to stop the car displaying an error. Now with the lights fitted they remain lit albeit very dim when the fogs are switched off. How do I cure this? Cheers |
02-10-2014, 12:46 PM | #2 |
Rep 114
they will probably turn off after a few minutes along with the other random electrical components that stay "on"after turning the vehicle off. otherwise, id assume resistors would be a good cure but i have no idea. in fact everything i said can be complete garbage.
Do You Even Meisterschaft?
02-11-2014, 12:15 PM | #3 |
16
Rep 243
Drives: 2013 335i M-sport
This is probably a result of the coding you used. Check to make sure there isn't better coding available.
03-04-2016, 10:47 AM | #4 |
199
Rep 1,114
did you fix this?
My Ride! : 2015 428i GC (F36) - MSport, Alpine, Black Leather, MBrakes, Adaptive, Sport Seats, Hex. Alum w/Piano, HK Sound, 400m's, Comfort Acc. When I’m not Driving: https://youtube.com/shorts/ViKD_Hj5htE?feature=share
03-05-2016, 05:39 AM | #5 |
BMW Fanatic
331
Rep 1,076
Get some CanBus wires. A forum member had a similar problem and solved it with that.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
