Walbro 400lph e85 mix
02-07-2014, 02:15 PM | #2 |
321
Rep 710
Drives: 23 M3 Competition
Need more information. Do you have the Walbro 400lph installed?
14 F30 N55 AWD SpeedTech EFR-8374, E70 MHD, Motive tuned
23 M3 Competition - Stock |
02-07-2014, 02:18 PM | #3 | |
Rep 51
02-07-2014, 02:25 PM | #4 |
456
Rep 6,478
All depends on the health of the stock low pressure side. Think you'll run into problems running more than E40, it certainly won't support that over the long term. @Jstang is running E40 on the stock system IIRC, think his pump is getting pretty tired. Mine was starting to call it a career at E30 so i replaced it and added the FFTEC pump.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
02-07-2014, 02:28 PM | #5 |
321
Rep 710
I can run up to E45 on my stock pump. Others can run up to E50. It's not recommended to go over 50% ethanol on the stock pump.
02-07-2014, 02:28 PM | #6 | |
562
Rep 3,625
02-07-2014, 02:29 PM | #7 | |
Rep 51
02-07-2014, 02:33 PM | #8 |
456
Rep 6,478
Not quite understanding what you mean here.
On stock fueling-assuming a healthy pump- I wouldn't go much over E40. With a healthy stock pump and an inline or in-tank upgrade, you can support full E85 though if doing that you should log diligently and make sure the high pressure side isn't tanking. Mixes like E50-E60 will be easily supported.
02-07-2014, 03:01 PM | #10 | |
456
Rep 6,478
What we are talking about here is an inline booster pump on the low pressure side. If you add an inline or in-tank pump, yes E50-60 is not a problem in the least.
02-07-2014, 03:03 PM | #11 | ||
Rep 51
02-07-2014, 03:07 PM | #12 |
456
Rep 6,478
We’re just talking past each other at this point.
There is no upgrade for the HPFP. No such thing exists. A walbro LPFP upgrade will allow you to run high % concentrations of ethanol. So yes, E40 would be a walk in the park under those circumstances. You could get away with E40 on stock fueling assuming the stock pump is in good shape. But IMO you’d be pushing it, I would upgrade.
02-07-2014, 03:29 PM | #14 |
456
Rep 6,478
The N54 has two critical parts to the fueling system, the low pressure side, and the high pressure side. They are fundamentally distinct, and operate under vastly different pressures. What we are discussing here, and was has been worked on by the community, is a solution to assist the low pressure pump. So all this walbro inline talk is specific to the low pressure fuel pump (LPFP).
There is no solution to the high pressure side. Period.
02-07-2014, 03:30 PM | #15 |
84
Rep 1,099
^LOL
hpfp = high pressure fuel pump lpfp = low pressure fuel pump your car has both you can only upgrade the lpfp no upgrade exist for hpfp add an inline (second) lpfp to help the stock lpfp so you can run e50-e60 safely |
02-07-2014, 03:37 PM | #16 | |
Rep 51
02-07-2014, 03:57 PM | #17 |
Guest
Rep n/a
Drives:
Peeps keep saying that there is no solution for upgrading HPFP, but what about the Vargas modified ones?
http://www.e90post.com/forums/showthread.php?t=828425 Are they no longer being sold? (Couldn't find anything on their website) |
02-07-2014, 04:12 PM | #18 | |
Rep 51
02-07-2014, 04:12 PM | #19 |
135
Rep 692
I have the Walrbo 450LPH in-bucket LPFP upgrade & run straight E85, no problems, fuel trims always sub-25%. If I had to do it over I would either:
This is their Coyote Mustang Billet Fuel Hat Highlight Specs: Billet Aluminum Fuel Hat, Bracket Holds 3 Walrbo 400 or 255s, Integrated merge, -10 AN Fuel Line Feed, 30 AMP Relay When this is released, if it allows you to run 2 LPFPs without shorting anything, I'll ditch my hacked-up OEM bucket and swap this in.
Results > |
02-07-2014, 04:20 PM | #20 | |
Rep 51
02-07-2014, 04:23 PM | #21 | |
456
Rep 6,478
02-07-2014, 04:26 PM | #22 |
172
Rep 1,910
I have the walboro in tank 400 or 450 lph pump or whatever it is...Been running e50-e60 for 25k miles. no issues. You will need to keep a close eye on monitoring parameters and after my recent battle with misfires, I'm pretty sure using e85 results in having to change your spark plugs more often lol.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
