2010 2011 BMW 5 Series Forum F10 DIY - Remove Chrome Trim Handle Strips F10 |
02-06-2014, 04:09 PM | #1 |
28
Rep 451
I wanted to plastidip my chrome handles black (to match the black line), but I could not spray on the the handle and peel back to reveal a crisp line. So I decided to remove them and paint them off the car.
AFTER: NOTE: I also plastidipped the side marker lights Here is what I did: First, get a plastic pry tool (I used this one): Carefully pry the front end of the chrome piece out: NOTE: FRONT OF CAR IS TO THE LEFT Then feed some dental floss through the gap and drag from front to back to unstick the double sided tape that holds the chrome trim piece to the handle. Once the tape has been separated, you need to push the chrome trim forward (toward the front of the car) so that the rear of the chrome trim can clear its key way. Be careful to not snap the plastic fins trying to remove it. NOTE: REAR IS DOWN This is what it looks like with the two different clips and the holes they go into: NOTE: FRONT IS TO THE LEFT AND REAR IS TO THE RIGHT (PIC IS UPSIDE DOWN) Next, use goo gone to remove the tape from both the handle and trim. Paint the chrome as desired and install 3M double sided mounting tape to the trim. Re-installing is easy enough: Peel back enough (1/2" or so) of the tape backing nearer the front (smaller clip) and fold over so that when it is installed, you can grab it. Slide the rear tab back into its key way and snap in the front clip. Grab the tab you made and peel from the front of the trim piece to the rear. Apply plenty of pressure to bond the two pieces together and you are done! Mine have been plastidipped for about a year now and it has not peeled at all, even though the car is washed about two to three times a week at a regular, non-touch free car wash.
2007 E92 335i / Montego Blue/Black - European Delivery - Retired
2013 F10 550i / Alpine White/Cinnamon - Retired 2014 F10 M5 / Singapore Gray/Sakhir Orange - Retired 2016 F15 X5 XDrive50i / Black/Black - Current __________________________________________________ |
05-28-2014, 01:14 PM | #3 |
MSGT USMC (Ret)
17
Rep 276
Drives: 2012 AW F10 535i M-Sport
Nice job. I'm a believer in plasti-dip, dipping wheels, diffuser, etc. You can actually spray clearcoat over plasti-dip to give it a glossy and smooth to the touch feel. I did it on wheels and it turned out great. Then plasti-dip back ove the clearcoat to remove like normal plasti-dip, no problems.
06-13-2014, 03:21 PM | #4 |
27
Rep 236
Drives: 335d
Nice...... I was actually able to do mine without taking the trim pieces off. Just had to tape off everything really well. It was a while ago and I think I used 5 or 6 coats per door. Peeled right off just fine for me. Go figure. Yours looks great though!
Enjoy what you drive.
