Long cranking of restarting
02-02-2014, 10:09 AM | #1 |
Rep 43
Dears,
I have almost a double cranking time on restarting my engine, but it doesn't happen when the engine was cool. What clue of it ? I did replace the ignition coil, spark plug, wide band sensor before cat, of course cranking doesn't take any data from wide band sensor Tks! |
02-02-2014, 11:23 AM | #2 | |
19
Rep 228
Drives: 2011 bmw 335i xdrive M-Sport
2011 BMW 335i xDrive M-Sport, Alpina B3 TCU flash, JB4 (ISO 5.3, Map 5), BMS DP, BMS Intake, BMS CP, KW V1's
02-02-2014, 07:29 PM | #3 |
Rep 27
Drives: E90 LCI 335i
I am having the same problem....doesn't happen all the time, couple times a week. I took the car in and had the high pressure fuel pump replaced to help fix the problem. Seemed to help the first couple of days, but I am still having the same problem, especially on restart. I am bringing the car back to the dealership on Tuesday, said that the injectors probably need to be replaced. The guy said they are seeing a lot of injectors needing to be replaced. I will let you know how it turns out after that.
2011 335i N55 |
02-03-2014, 01:05 AM | #5 | ||
Rep 43
thankyou for all inputs!!!
mine has fixed the DCT gearbox oil leakage under factory warranty in Dec 2013, I think it was due to their design defect so BMW fix it up without charges! this was the second time bmw replaced the gearbox covers without charges to fix the oil leakage issue. Quote:
do you get any engine fault light when you were in full throttle. mine has came up twice:- the first one is just fill 40L gasoline then I pressed the paddle to the ground in the first 1000 meter I got engine light up and said your "engine fault" full engine power no longer available..... the second one was fuel level warning light up (fuel under normal level), after few KM then I got engine light up "engine fault" when I pressed full throttle after few seconds.... BTW, does anyone try to read the fault code by their own laptop, what kind of cable and software i have to prepare? |
02-03-2014, 05:09 PM | #6 |
Rep 171
Same hear with long cranks some times. Have you guys replaced the battery cable that is a recall? I heard some people say that solved the problem for them.
02-03-2014, 05:18 PM | #7 |
7478
Rep 10,120
02-10-2014, 09:48 AM | #10 | |
Rep 43
Then did the replacement at Saturday took about seven hours to complete it. Problem I have was insufficient lighting in the car park. And tested it was fine on Saturday night everything works very good. At Sunday I drove about few km but smell some gasoline came out from engine near intake manifold. I clean engine air inlet area that faced to gasket and intake manifold gasket. reseat intake manifold, high pressured fuel line, it took about few hours then start the engine again. No more gasoline smell, I thought due to air leakage between engine air inlet and intake manifold. I drove today more then 50km from my home to office and back to home. tested full throttle, under traffic jam and refill the fuel tank. No long cranking on restarting and everything works fine! |
02-10-2014, 11:34 AM | #11 | |
19
Rep 228
My car was originally delivered in September 2010 so my warranty expires Sep. 2014.
02-10-2014, 11:34 AM | #12 | |
enthusiast
117
Rep 997
Drives: 2011 e92 lci 335xi
