TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > sloppy suspension
      01-27-2014, 02:18 PM   #1
46m3csl
121
Drives: 335i
sloppy suspension
Like after speed bumps or even taking corners off quick turns the cars very slow to react back it feels laggy and unresponsive. Even our camry seems to have a faster recovery when going over the speed bumps it feels soft but it tightens up quickly as my car it seems to bounce a bit and like the laggy bounce motion.
      01-27-2014, 02:22 PM   #2
benjlv
Drives: 97 m3, 06 330i, '13 x3, '14 x5
to help guide you, can you answer the following questions?
what suspension package did you order with your car?
how many miles?
what tires are you using?
Have you replaced anything in the suspension?
      01-28-2014, 03:49 PM   #3
46m3csl
121
Drives: 335i
I have the sport suspension from factory. I am on 19 inch avant grade rims with hankook v12 tires, along with about 75,000 miles on the car. Nothing on the suspension has been raplaced
      01-28-2014, 04:52 PM   #4
Jdub679
88
Drives: 2011 BMW 335i coupe M Sport
In my opinion, the Hankook V12 tires' soft sidewall makes it feel like there's a lot more body roll in turns. You can resolve this with a better suspension (coilovers or struts/springs), better tires (like the Michelin PSS, which has stiffer sidewalls), or with parts like the M3 front control arms (which have stiffer bushings).
I went with the M3 front control arms. And will be getting new tires within about 6 months or so.
      01-28-2014, 07:10 PM   #5
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
Also the extra weight of 19" wheels isn't helping, but mostly it just might be tired dampers. Try a set of Bilsteins or Konis.
      01-28-2014, 08:27 PM   #6
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
First check inflation pressure. With the cold, tires tend to loose several psi, and that can feel really odd. But yeah, at 75k miles the suspension start to get tired.
      01-29-2014, 10:18 AM   #7
46m3csl
121
Drives: 335i
What are some good dampers if I have to buy some, and are controls arms possible to do at home? Am assuming a alignment is needed for all this after? Any bushings I should look into replacing?
      01-29-2014, 12:11 PM   #8
Volasko
Volasko's Avatar
705
Drives: 06 330i E90, 18 530xe G30
See my garage for everything I replaced when my stock shocks started to crap out. Trying to DIY everything would take some time.
      01-30-2014, 08:18 AM   #9
BMWNTHZST
Enthusiast
BMWNTHZST's Avatar
194
Drives: 2015 F80 M3
2011 BMW E93 M3  [0.00]
2004 BMW M3  [9.50]
2015 BMW F80 M3  [0.00]
1997 BMW 840CI  [9.50]
2011 BMW X5 M  [10.00]
2008 BMW 335i Conve ...  [8.40]
Are you happy with the upgrade? I would like to change out my suspension too to something that closely resembles the feel that my E92 M3 without breaking the bank.
When driving in a stright line and hitting a bump the car will sort jump sideways. The rebound also sucks.
Just looking for solutions.
2017 Porsche 718 Boxster Carerra White / Garnet Red / Black
2013 Porsche 991.1 911 Carrera S Platinum Silver Metallic / Black and Yellow accents
2014 F31 328i xDrive Alpine White / Black
      01-30-2014, 11:23 AM   #10
46m3csl
121
Drives: 335i
Am having the rebound jump to the side problem as well, did you find out the cause of it?
