E92 brake pointers
01-26-2014, 12:18 PM | #1 |
17
Rep 251
Drives: 2007 BMW 335i Coupe
E92 brake pointers
Just finished brakes all around on my 07 e92 and thought I would put up a couple points to help others.
One point was that the clip on the OEM pads that hold the brake sensor in place does not work with aftermarket pads so they do not fit back on as snug as with the OEM pads. Need aftermarket brake sensors as well. Another point is of you plan on replacing the rubber sleeves for the caliper bolts the longer ones in the front calipers are a bear to get back in. Needed 3 hands and a small pry bar to constantly keep pressure on the rubber sleeve while prying around the rubber closest to the hole until it gets past the lip that ends up on the back side of the caliper. Lastly when putting the lower rear caliper bolts in the lower control arm is in the way so a 3/8th's swivel is hugely helpful when trying to thread the bolt back in place.
* 2007 BMW 328i Coupe Black - Stock - Sold
* 2009 Porsche Cayman Black - Stock - Accident Leaves it sitting in my Garage * 2007 BMW 335i Coupe Space Grey - JB4 Tune, Cone Air Filters & Stainless Cat Elmination Down Pipes |
