Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Service Engine Soon
      01-24-2014, 06:49 PM   #1
SimplyBS
Drives: 2013 328i
Service Engine Soon
On the way home today had the light come on. Checked the codes and the following were logged.
P205B
P3EED
C0D32
I found some info on the first, but can not find anything on the other two.
      01-24-2014, 07:29 PM   #2
GreekboyD
411
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
Are you running an engine tune?
      01-24-2014, 07:34 PM   #3
SimplyBS
Drives: 2013 328i
JBD. Do you know what the codes mean?
      01-24-2014, 07:36 PM   #4
GreekboyD
411
My buddy says the first one is DEF tank related while the others might be due to a tune, the DDE spitting out the codes. Says the first one is the main concern.
      01-25-2014, 01:21 PM   #5
SimplyBS
Drives: 2013 328i
Reset the code yesterday and the 205 and C code returned.
      01-25-2014, 02:13 PM   #6
Poosik
23
Drives: BMW 335D
What type of scanner do you have?
      01-25-2014, 02:46 PM   #7
SimplyBS
Drives: 2013 328i
Using an ELM327 wifi using EOBD facile iphone app. Cleared with JBD cantool.
      01-26-2014, 05:21 PM   #8
Brad335d
Oil Burner
Brad335d's Avatar
26
Drives: 2011 BMW 335d
OK so code one I CANNOT find a P205B but I CAN find a P20B5 which has 3 sub codes which can be further diagnosed with an OEM capable scan tool. I will post all 3 sub codes for you. Your scanner in only reading the generic P20B5 code and not the manufacturer specific code of i.e. 4601, 49E2, etc. The code P3EED and COD32 DO NOT correspond to any code I have listed in my AllDataPro system. If you are using a generic scan tool which I suspect you are it is most likely generating an ambiguous code that doesn't apply to the car.
1) 4601 - P20B5
Information saved in
DDE
Fault code
4601 - P20B5
Fault text
DDE: Reducing agent, output of delivery module heater too
low: Open circuit, heater circuit
Fault description
The error is recognized when no lead value stroke has been
recognized after a specific period of time, meaning that the
lead value remains below the threshold 0 1/Ohm.
Condition for fault identification
Test condition:
A check for this error runs once per heating cycle.
Voltage condition:
Condition for fault memory entry
Event debounced (1)
Action in service
Check resistance of delivery module heater unit.
Replace delivery module.
Fault effect and breakdown warning
Driver information
Warning light:
MIL
Service instruction
Delivery module heating unit resistance:
2.9 - 5.5 ohms
© 2014 ALLDATA LLC. All rights reserved. Terms and Conditions
2)49E2 - P20B5
DDE
Fault code
49E2 - P20B5
Fault text
DDE: Heating, SCR system, power peaks: maximum heat
output too high
Fault description
Monitoring peak power in reduction agent pressure line
heater. A short circuit is recognized when the peak heater
output is above a limit value defined based on operating
point and the peak power test has been completed.
The peak power test is terminated when one of the following
conditions is met:
- An activation signal has been transmitted to the heater for
at least 10000 ms.
- When the peak power test has been recognized as
terminated based on the shift in the heater's power.
Test condition:
The error check runs once the peak power test has been
completed.
Voltage condition:
completed.
Event debounced (1)
Action in service
Check resistance of heater elements.
Check heater wires for short circuits to ground.
Driver information
Warning light:
MIL
Service instruction
none
3) 4C72 - P20B5
DDE
Fault code
4C72 - P20B5
Fault text
DDE: Reducing-agent pressure-line heating: Short circuit,
heater circuit
Fault description
Monitoring of reduction agent pressure line heating. The
diagnostic trouble code is logged when the measured current
draw from the deactivated heater exceeds the limit value
150 uA.
Test condition:
The error check runs continuously when the urea tank heater
is deactivated.
Voltage condition:
is deactivated.
Debounce (15000 ms)
Action in service
Check the control wire and the diagnostic wire.
If wiring and plug connections are OK:
Check plug connections for moisture.
Use diagnostic system to test heating systems.
Replace power switch.
Driver information
Warning light:
MIL
Service instruction
The power switch transmits an activation signal to all
heaters. The first heater circuit is for the active tank heater,
the second heater circuit is for the delivery module and the
metering line.
The control wire should not be in contact with ground or B+
when the DDE and power switch are unplugged.
'11 BMW 335d Sport
-JBD
'07 Shelby GT500
-Not Stock
