Advice on Differential/Posi Traction!!
01-24-2014, 05:40 PM | #1 |
Rep 54
Hey Guys- Not sure if i'm posting this on the correct thread so if im not let me know please. I got a 2008 E92 and looking to get power to both real wheels. Looking for some advice as to what to go with as far as brand/maker and any idea on price. I looked into the DINIAN DIF and it cost around $3,800 installed. I thought that is a little high?? Any advice?? Thanks!!
01-24-2014, 05:51 PM | #2 |
34
Rep 1,093
You want an LSD that fits in our pumpkin. Quaife is one. I forget who makes the other one. should be under 1000 for the part. Install is DIY'able
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
01-24-2014, 06:25 PM | #3 |
73
Rep 963
Install is diyable only if your current diff is bolted and not welded to the fly wheel. Or if you are handy with a torch and a CNC grinder. Unfortunately you won't know until you take it apart but odds are if you are 2007+ yours is welded. I also read accurate shimming is important.
Good read here http://www.e90post.com/forums/showthread.php?t=648271 Distro in UK from birds. Or VAC or HP in USA. Wavetrack is the other major brand. |
01-24-2014, 09:07 PM | #4 |
60
Rep 333
Interesting.....But why not just buy a new ring and pinion (exact same ratio) instead of all the costly machining? Or just get a good used M3 diff and slap it in?
11 E92 ZCP
02 Honda S2000 -741 whp 471 wtq (dynojet) @ 29.6 psi on e85; now on 34 psi, 800+ whp. |
01-25-2014, 07:40 AM | #6 | |
41
Rep 1,257
OP, M3 rear dif requires the M3 rear subframe and a custom made driveshaft. It is not even remotely close to a real slap in solution. As for buying new and unnecessary parts that will still cause you shimming issues for proper backlash and preload...just buy a wave track or quaife from Harold at hpautosport or from VAC motorsport. I think total cost on either of those units WITH machining is 2thousand something. |
01-25-2014, 10:28 AM | #8 | |
177
Rep 2,301
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
05-18-2023, 07:36 PM | #10 | |
Rep 1
