The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Alignment Complete by Auto Couture. How does this look?
      01-23-2014, 12:22 PM   #1
WhiteFury
Boooost!
WhiteFury's Avatar
70
Drives: 335i
So I finally got my alignment done by auto couture motoring after lowering the vehicle and putting 19 inch wheels on the car.
He said this is the max came right and get out of the front, I plan on getting SP perches soon.
I provided a picture below, how does this alignment look at -1°Is it bad for the front tires? Will I experience any tire wear with this alignment set up?
Also if I want to go ahead and use ASPI perches will I need to get 335 I strut tops, the SP perches themselves and the rubber part that goes between perches and sprints?
If I get the SP perches I'm sure that the front is going to drop about a quarter to half an inch, and my camber might go more negative at that point right? The reason I ask is I might get Turner motorsports camber plates.
Here's the factory plates I found for the 335i
http://www.fcpeuro.com/products/bmw-...FfM7OgodQWkAhA
Thanks!
JB4 Stage 2 | Injen CAI | BMW PE | AR Catless DP | Alpina TCU Flash | Eibach Pro Kit | Custom TCKline Koni's | 19" M359 Wheels | DWS Tires
      01-23-2014, 12:24 PM   #2
tc535i
215
Drives: 2007 335i, 2001 330i, 1995 M3
toe looks great, you were WAY off before! Those rear tires must have been taking a beating
      01-23-2014, 12:25 PM   #3
tc535i
215
1 deg of camber is almost nothing, with your slight toe I wouldn't worry at all about wear
      01-23-2014, 02:29 PM   #4
WhiteFury
Boooost!
WhiteFury's Avatar
70
Drives: 335i
Ok awesome! How about the perch setup. Do I have the right idea and direction?
Also I forgot to mention they didn't put any weight in the car when they aligned, will this be a problem when I have weight in the car?
      01-23-2014, 05:16 PM   #5
psmitty95
psmitty95's Avatar
578
Drives: '23 M340i xDrive
Any chance you want to share how much they charged you? I'm shopping around for an alignment in the spring when I get new wheels
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion
Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning
More Pictures: Build Thread /// 683AWHP/675AWTQ
      01-23-2014, 05:17 PM   #6
tc535i
215
I wouldn't change anything without realigning
weight isn't going to be a noticeable issue, this isn't a nervous track car with toe out or anything
      01-25-2014, 11:23 PM   #7
WhiteFury
Boooost!
WhiteFury's Avatar
70
Drives: 335i
The paper says 18" wheels, the tech said that it came with a max size of 18's from the factory. I have 19's. Could that throw the camber readings off?
Also what is the best route to getting camber adjustment? Also I am wondering if i go with perches and they lower my car .5 inch more, how much more camber will it go negative?
