DIY: Coding Seat Occupancy Sensor and Airbag light.
01-20-2014, 06:53 PM | #1 |
130
Rep 645
Had to get this done recently, and we had some difficulty finding the right options to code. Turns out there are two extra steps needed for newer cars.
Here are the steps: Set the following to "nicht_aktiv". SIDEBAG_LINKS_1 SIDEBAG_RECHTS_1 OC3_1 For newer cars (ie: E90 LCI) The following needs to be "nicht_aktiv" as well. AKS_LINKS_1_CD AKS_RECHTS_1_CD. We found the first three steps really easy, but the airbag light still wouldn't go off, im not sure many people are aware of the two extra steps for newer cars. Cheers. |
12-30-2015, 03:01 AM | #2 |
26
Rep 137
I have a 07 E92 M3 and had my original Driver side seat change to bucket seat.... can I follow the same step to clear out the SRS warning light on my dash board? Thank you
E92 6spd, Endless 6POT w/ MX72Plus, W003 & ME22. KW Clubsport 3 way, Akra Evo, Rays ZE40 w/ RE71R, BPM tune
12-30-2015, 03:06 PM | #3 |
Rep 15
The last two steps must be for the Active headrest restraint system
12-31-2015, 05:29 PM | #4 |
153
Rep 438
Drives: F30 335i M Sport
for the seat occupancy sensor, you do the following.
set oc3_1 to nicht_aktiv Unplug the sensor (Really easy if you remove the seat) Clear fault codes. This is really common for sport seats, I've done this for tons of cars. |
Volum14.00 |
01-04-2016, 08:53 PM | #5 |
48
Rep 139
I have two '08 335xi; the one I want to sell had sport seats, the one I am keeping did not. Therefore, I have swapped seats so that I have the sport seats (and sport steering wheel) in the car I am keeping.
However the sport seats have an airbag on the side and the basic seats do not. Therefore the car that had the sport seats now wants to throw an airbag code; while I can clear it with Carly, it comes back after disconnecting the battery. I am just becoming familiar with NCS Expert. Does anyone know what codes to change to swap between sport seats (with side airbags) and basic seats (with no side airbag) ? Thanks.
2017 M3 DTC * 2013 M3 Manual
2017 330i (Winter beater) 1981 Camaro Z28 - 427 LS3 - 10.94 @126mph 2006 Corvette (streetable track car) 1986 535i "24 Hours of Lemons" also streetable |
01-04-2016, 09:26 PM | #6 | |
26
Rep 137
Thank you
01-04-2016, 10:34 PM | #7 | |
48
Rep 139
I also suspect that many different airbag faults can enable the SRS light and that Carly cannot clear all of them.
01-05-2016, 08:15 AM | #9 | |
48
Rep 139
Reading with NCSEXPERT my FSW_PSW_TRC has over 8000 codes - hoping someone knows which codes it is or even might be. Tonight I will read the other car so that I can examine the code differences between the cars. Or perhaps it will be better/easier to swap the relevant VO codes between the cars. Update: Looks like swapping VO code $488 (Sport Seats and Steering wheel) might do the trick.
2017 330i (Winter beater) 1981 Camaro Z28 - 427 LS3 - 10.94 @126mph 2006 Corvette (streetable track car) 1986 535i "24 Hours of Lemons" also streetable Last edited by mrvedit; 01-05-2016 at 10:21 AM.. |
01-30-2016, 08:22 AM | #10 | |
153
Rep 438
01-31-2016, 08:43 AM | #11 |
48
Rep 139
Oops, I should have updated my thread here as updating the VO codes for both cars and factory coding the related modules worked.
09-03-2019, 03:26 PM | #12 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
OP's coding did not work on a 06 e90 for disabling the OC3 passenger mat seat sensor. Doing that gave me additional sidebag errors.
The post below from RogerOK did work for me. https://www.e90post.com/forums/showt...=583819&page=4 |
09-03-2019, 03:34 PM | #13 | |
185
Rep 780
08-30-2023, 05:29 PM | #14 | |
Rep 7
I am not finding these codes in protool. What am I missing? |
08-30-2023, 05:51 PM | #15 |
1917
Rep 13,109
Normally when people want to bypass the seat sensor failure they buy
a seat sensor bypass. I had mine seat sensor replaced under recall. Last edited by ctuna; 10-01-2023 at 07:25 PM.. |
08-30-2023, 06:01 PM | #16 | |
Rep 7
09-24-2023, 11:50 AM | #18 |
21
Rep 73
As OP mention + if not already shared by some1 you need to UNPLUG the seat occupancy sensor from underneath the seat for the airbag light to go out.
10-15-2023, 08:20 PM | #19 |
eBay Special
3078
Rep 3,031
Drives: E90 330xi
Whenever I forget how to do seat mat coding (I do a lot of seats) I always search for this thread- for this very comment right here. Works without fail every time.
