lowering suspension?
01-19-2014, 11:42 PM | #1 |
Rep 30
Drives: N/A
I have Set of 19X8.5 19X9.5 Avant Garde M310s Gunmetal w/ Machined Face with Goodyear F1 Asymmetric 235/275 combo.
my e92 335xi is base model. I researching and found out that H&R spring and koni is one of the popular(?) set. Other than those two, is there anything I also need to replace since it is a base model? |
01-20-2014, 07:26 AM | #2 |
Rep 136
Drives: Montego E92
No. Not unless you want additional performance. If so, then I would research thicker anti sway bars and the M3 control arm upgrade.
If just to look lower and kill fender space, that's all you need. You will not need a camber correction plate for said springs. (At least I did not). |
01-20-2014, 09:00 AM | #3 |
Rep 30
Drives: N/A
thanks! but if i were to lower, would there going to be problem with 19" tire touching the body of the car?
01-20-2014, 10:25 AM | #4 |
Rep 136
Drives: Montego E92
No, I have 19's, too. The space you gain in wheels size you lose in tire height, so in reality, it's not much of a difference minus the visual look of becoming closer to the fender via thinner tires.
01-20-2014, 10:27 AM | #5 |
Rep 136
Drives: Montego E92
One other fun fact; the XI's sit higher anyways, so you really shouldn't have anything to worry about. I rock 10MM spacers and had rubbing issues only on speed bumps.
01-29-2014, 12:53 AM | #6 |
Rep 30
Drives: N/A
would you recommend koni yellow or koni fsd? I am asking for daily driving purpose.
01-29-2014, 12:56 AM | #7 |
Rep 30
Drives: N/A
how about the koni adjustable?
here is the link: http://www.**********s.com/Koni-Fron...ks-E90-E92.htm ***m.o.d.b.a.r.g.a.i.n |
